Old 10-28-2016, 11:08 PM   #1
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
900 WHP on nitrous?
For discussions sake.
What does it take to make 900 WHP on a 416 "assuming a 250 shot or kit capable of 250"?
Curious about some of the more informed opinions about this.
UNRIVALED SS is offline   Reply With Quote
Old 10-29-2016, 07:40 AM   #2
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Probably gonna take more than a 250 shot, especially if an auto.
Expect 550-600rwhp on a well built motor...
RealQuick is offline   Reply With Quote
Old 10-29-2016, 08:11 AM   #3
UNRIVALED SS
Agreed
This question was based on some pretty cheap talk that took place at the local 1/8th mile last night. I for one don't know 1/10th of what's out there because these days there is a lot on the table to make power in terms of parts and options.
I don't know of any possible way to make 900 RWHP on a 250 shot of nitrous from a 416-17 that will live on the street. I know the crew that commonly reads the posts here have seen quite a bit that I haven't. So I thought I would pose the question for some quick Saturday morning feedback. So far just what I expected.
Old 10-29-2016, 08:21 AM   #4
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
No problem if you have a Supercharger with that shot of Nitrous but on Motor no way imho. I am 530-550 rwhp pump gas and will be running a 150-200 shot dual bottle setup for 1/2 mile if I ever get it hooked up. Been months just sitting. So much left to do to car and no time to get it done or Race until after Jan. :(
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 10-29-2016, 09:22 AM   #5
RealQuick
And to be clear about my other post, 550-600rwhp on a well built motor N/A... Before nitrous.
Old 10-29-2016, 11:37 AM   #6
UNRIVALED SS
Yes , if someone could come up online with nitrous non dual power adder car making even 800 I would be curious to know details about that combination. Understand I have no grief with nitrous in this discussion. It makes awesome power especially per dollar. I just don't have any idea what it takes to make the 800-900 WHP number.
Old 10-29-2016, 12:04 PM   #7
CGbambam
Drives: 2011 Camaro 2SS
One hell of a strong drive train, built block and a lot of nitrous (300/400 shot). Definitely some kind of progressive system to deliver it. 900hp and on nitrous i would expect the torq figure to be at least 1000 if not more. Suspension of course just not to blow your tires on every run.
CGbambam is offline   Reply With Quote
Old 10-29-2016, 01:28 PM   #8
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Just to point out the obvious but most guys spraying big shots go direct port, dedicated fuel system as well with race gas
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-29-2016, 06:18 PM   #9
UNRIVALED SS
Based on the feedback so far I can assume it's not likely to run across a street car with a 250 shot making 900 WHP. I didn't think so. Track side talk is pretty cheap but not usually this cheap.
Old 10-29-2016, 06:49 PM   #10
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Most I've seen with my own eyes was 695rwhp on a cammed 376 LS3 and 250shot. Was running a separate race gas cell when on the nitrous hit.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 10-30-2016, 12:25 PM   #11
UNRIVALED SS
That's about the power level I've seen as well. I just don't know how anyone can squeeze 900 out on a ligit street car on a 250 shot. I know there is a large audience here to vet this with.
I may ease a litltle nitrous into my ole heap this winter. When I say ease, I mean not much. I like the the way the car drives now buuuuuuut, there are those times when you really don't want to see someone's tail lights.
Old 10-30-2016, 01:26 PM   #12
CGbambam
It is possible thought on a 250 shot but like i said you're talking about some kind of after market block or perhaps a ls7 to hit 900 . Liek high compression + e85+ ported heads + ported intake. Basically a max effort engine, every trick in the book. That's just power wise, not including drive train etc etc etc. You're talking about some good cash involved
Old 10-30-2016, 05:59 PM   #13
Warhorse
Warhorse's Avatar
Drives: 2011 Syn Green Camaro
When the little TVS2300 is not enough and your too stubborn to change! This would help the OP reach his goals.
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!!
Warhorse is offline   Reply With Quote
Old 10-30-2016, 07:52 PM   #14
UNRIVALED SS
Warhorse ! Nice work there! If you don't mind I would like some details. I like the very clean look of the setup you have there. I would also like to know how the PATC trans is treating you at whatever power level you are at.
Feel free to PM if you like.
