06-05-2014, 01:31 PM | #1 |
Drives: 2017 2SS 50th Anniversary Join Date: Apr 2013
Tonneau cover at High Speed
Has any found a way to keep the cover from raising up in the middle from air pressure. I give my car a little gas and next thing I know I have a para-sail with only the 2 bungee cords holding it on, very annoying as I have to stop car and reinstall the cover, makes me want to not run with it at all when going down interstate.
06-05-2014, 02:45 PM | #2 |
Drives: 2015 2SS Convertible Join Date: Sep 2013
I have yet to put mine on. Come to think.... I don't know how to put it on. Lol
06-05-2014, 07:42 PM | #3 |
Drives: 2011 2SS Convert; Color RJT Join Date: Sep 2009
Here is a link to my experience and fix.
http://www.moderncamaro.com/forum/677649-post7.html Hope this helps. |
06-05-2014, 08:45 PM | #4 |
Drives: Oracle Camaro has all the bells & Join Date: Jul 2010
That's the fix, I'm going to use but have not gotten it sewed on yet. I don't think about it too often until I hit a interstate. Around here its top speed of 55 & I've got to drive 50 miles to a interstate. Michael
06-05-2014, 09:46 PM | #5 |
Drives: 2014 Bright Yellow ZL1 Vert/M6 Join Date: Apr 2012
I put a large washer on each of the screw heads making it hard to put on but it is always seated very tight, even tested at going from California to Florida to Michigan at highway speeds!
06-05-2014, 11:32 PM | #6 |
Drives: 2014 CRT Convertible ZL1 Join Date: Nov 2013
No issues with mine but its a 2014
Sent from my Nexus 7 using Tapatalk |
06-07-2014, 10:48 PM | #7 |
Drives: 2013 Black Camaro 2SS/RS Convert. Join Date: Jun 2013
No problems here. I have a 2013 with the bungee cords
2013 Camaro 2SS/RS-Smoked tail lights and side markers, HID log lights, & LED lighting inside/outside the car, SJM LED Cupholder, SJM full dashboard ABL lighting, ZL1 Rockers, 1LE Splitter, Showstopper LED Mirrors, Showstopper LED Side Markers, & Showstopper Heat Extractor Hood, 20" Niche Concourse ZL1 Styled wheels 20X8.5 & 20X10 with 275/40/20 & 315/35/20 Nitto Invos, Black Gorilla Lug Nuts/Locks, Black Billet Elite Camaro License Plate Holder, and Hydro Dipped Speedo/Shifter/AC-Heat Bezels.
06-07-2014, 11:24 PM | #8 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
06-08-2014, 02:38 AM | #9 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
But the OP has a 2013. Something is wrong with his particular tonneau or the way he installs it.
Are you sure you've got itbinstalled correctly? Are there any splits, holes or openings of any kind in the tonneau material? Mine works perfectly. Been over 100 mph.
Consensus is, by definition, a lack of leadership.
06-08-2014, 09:25 AM | #10 |
Formerly Lil'BlueCoupe
Drives: '13 2LT/RS Vert, Summit White Join Date: Jul 2009
Never had any problems with mine, other than the fact that I forgot it was on befor I went to put the top up.......oooops
Luckily nothing broke...
06-08-2014, 09:54 AM | #11 |
Drives: 2016 2SS Convertible Join Date: May 2012
Nice fix! I don't normally have problems with mine. It did pull up once at 75 mph on the interstate when there was a moderate cross-wind. Was surprised to say the least.
06-08-2014, 10:53 AM | #12 |
Maybe thats the issue - crosswind. Looks like it popped after the draft coming off the truck. Going to drive cross country this summer - we'll see what happens.
Sent from my XT1080 using Tapatalk |
06-08-2014, 01:55 PM | #13 |
Drives: 2012 camaro convertible 45th Ed. Join Date: Nov 2013
06-08-2014, 01:56 PM | #14 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
I have a 2013 and have been 160+ and no issues.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
