08-31-2012, 09:48 AM | #1 |
BRUCE WAYNES DD
Drives: 2010 2SS/RS CGM Join Date: Dec 2011
run fog halos w/ drl???
I just got the fog halo kit for my car!! what do i need to run the fog light halo and the top halos?? also what plasma bulb do i need to install in the fog lights to make them match the top? i have the aac halo...I heard there was a drl harness or something but i do not see it on their web site!!!!
08-31-2012, 10:01 AM | #2 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Your bulbs are p13w for your 2010 car, and all you do is t-tap to the 2 outside wires on the upper RS headlight connector, one will be black and its the ground and the other is PU, good luck, and if you want a DRL harness go to the sit below.
08-31-2012, 11:32 AM | #3 | |
BRUCE WAYNES DD
but how do i make so i can run with just the top and bottom halo`s on?? I dont want to always have to have the headlights on with the top halo |
08-31-2012, 11:42 AM | #4 |
knows 2 facts about ducks
Wire the fog halos up to your front side markets.
08-31-2012, 11:53 AM | #5 |
BRUCE WAYNES DD
then when the headlights are one will the drls be on as well??
what i want to accomplish is be able to run just the two sets of halos in the day. Also at night i want to run the drl fog lights and halos with the headlights on.Is this possible??? |
08-31-2012, 11:53 AM | #6 |
The 2 wires are not the headlight but the running lights same a stieger said, and all you do is turn your headlight switch one click for the running lights to come on.
08-31-2012, 11:55 AM | #7 |
So you dont want the DRL's on in the day time?
08-31-2012, 01:59 PM | #8 |
BRUCE WAYNES DD
not the actual fog light bulb... is there any way to control the halo and the buld in the fog light seperately???
08-31-2012, 08:39 PM | #9 |
Drives: 2010 SS/RS Join Date: Jun 2009
I have built custom harnesses for literally hundreds of members here on C5. PM me with your specific needs and I will work with you to ensure your 100% satisfaction.
08-31-2012, 11:57 PM | #10 | |
Not trying to thread jack just was curious myself!!
09-01-2012, 08:51 AM | #11 |
09-01-2012, 10:29 AM | #12 |
BRUCE WAYNES DD
I want to be bale to drive with just both sets of halo`s on by themselves. and i want to be able to drive at night with the drl and halo on...
09-01-2012, 11:09 AM | #13 |
Are any harnesses needed for 5202?
09-01-2012, 11:59 AM | #14 |
Drives: 2011 Camaro Convertible SS2/RS LS3 Join Date: Jun 2012
Currently I have my DRL's wired to my sidemarkers. So when the the DRL's turn on automatically, so do the Halos around my headlights.
I wrote about the wiring process here: http://www.camaro5.com/forums/showthread.php?t=240590 When I order the the Halo DRl's from AAC I plan on using them only as Halos. As far as I know, if I leave the factory bulb out, then the DRL's will simply be Halos. And since my DRL's are wired to the sidemarkers I should have two sets of Halos that turn on automatically. |
Thread Tools | |
