11-07-2016, 11:06 AM | #1 |
Drives: 2013 SS VERT Join Date: Oct 2016
L99 Resonator removed 2013 ss automatic
The car I bought used is an L99. The huge resonator has been removed. They added the exhaust that has 4 tips and it has the vacuum cutouts in the back but there is no vacuum hoses attached. It looks like the flappers are open all the time. it sounds pretty good. I noticed there is no "H" pipe. Is it needed and would it change the sound/ performance much?
11-07-2016, 11:41 AM | #2 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Not having the H-Pipe, you will loose a lot of low end torque. You will not be able to do burn outs. I myself love doing burn outs. It is cheap to have an h-pipe welded in.
Your fuel economy will also suffer. Last edited by Dimitrim; 11-07-2016 at 01:04 PM. |
11-07-2016, 02:48 PM | #3 |
Drives: 2012 Camaro SS L99 Join Date: Apr 2012
Is there an xpipe?
11-07-2016, 02:55 PM | #4 |
Drives: 2005 Corvette M6 Join Date: Sep 2016
I put an X-pipe where the resonator was after I removed it.
The muffler shop was very much against just putting straight pipes instead. |
11-07-2016, 06:28 PM | #5 |
old school chevy rodder
H pipe is contained inside the "suitcase" resonator of the l99 so yes you do need a crossover either h or x. It makes the engine perform better.
11-07-2016, 07:29 PM | #6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Someone please explain to me how a resonator / muffler delete can rob performance. Is it a proper back pressure thing??? Seriously, I don't know.
11-07-2016, 07:54 PM | #7 |
Dimitri
11-07-2016, 08:05 PM | #8 |
And these pipe arrangements are in the resonator or muffler or both? (or are the muffler/reso one in the same?)
11-08-2016, 11:09 AM | #9 | |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Good question I've been struggling to understand this too as I was thinking of deleting the 2 rear mufflers near the tips. I assume the resonator with H pipe is closer to the Cats? |
11-08-2016, 12:17 PM | #10 |
Drives: 2011 SS Join Date: Apr 2016
It's the x or h pipe that is what helps your performance. The engine is being exhausted in alternating pulses, so when one bank has very high pressure moving through the exhaust, the x or h allows some of the exhaust to move to the other side of the exhaust where the pressure is lower.
2011 SS
C.A.I. intake, headers, tune |
