03-09-2017, 12:57 PM | #1 |
Drives: camaro ss 2010 Join Date: Dec 2016
Oil press probleme
The car was normal same as the oil pressure when suddenly this happened. What might be the problem?
03-09-2017, 03:16 PM | #2 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
If your oil pressure pegged out at max, it's most likely the oil pressure sensor.
03-09-2017, 04:59 PM | #3 |
03-09-2017, 05:09 PM | #4 |
Drives: 2010 1SS Join Date: Aug 2015
Doing it with key on engine off? Then prob sensor.. If while running I would be careful. The pressure valves stuck and it could be stuck closed.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
03-09-2017, 05:16 PM | #5 |
Were you working on the car recently? The oil pressure sensor sits right behind the intake manifold and breaks very easily. If you have access to a data logger you can check to see if it's just a broken gauge pretty easy.
03-09-2017, 08:20 PM | #6 |
376 cubic inches of fun
Yup, a broken connection or failed pressure sensor causes a max reading, not a zero reading.
03-10-2017, 06:51 AM | #7 |
When i turn the key on
03-10-2017, 06:55 AM | #8 |
Yeah.. looks like either the gauge went or the sensor then.. would be looking at the sensor first.
03-10-2017, 08:58 AM | #9 |
03-10-2017, 10:03 AM | #10 |
Not sure what you mean? How it broke or how to ck? If you are are unsure you may want to take to your local technician.
03-10-2017, 10:53 AM | #11 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Reach around the back of the intake manifold on the drivers side with your hand and feel around for oil.
If you feel oil the sensor is cracked and needs to be replaced. You can get an OPSU(oil press sending unit) socket at any parts store.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
03-10-2017, 01:24 PM | #12 |
Originally Posted by sdynak
Yeah.. looks like either the gauge went or the sensor then.. would be looking at the sensor first. Originally Posted by iliassehk How ? If you have a smart phone you can get a OBD2 scan tool ~$20 and an app called OBD Fusion. Plug the scan tool in the OBD2 port, start the car and you'll see on your phone what the oil pressure shows. If normal then it's the guage. If high then it's the sensor Foseal OBD2 Scan Tool for iPhone & Android https://www.amazon.com/dp/B00W0SDLRY?psc=1 ODB Fusion app for iPhone & Droid https://www.obdsoftware.net/software/obdfusion |
03-11-2017, 07:32 AM | #13 |
It could be the sensor, but also it could be a damaged wire. The last time this happened to me (on a GMC truck) all that was needed was repair of damaged insulation on a wire.
Easier said than done on the Camaro. The truck's engine bay was big enough that I could basically get inside and see the entire engine wire harness. |
03-12-2017, 07:32 AM | #14 |
