Old 08-10-2012, 02:10 PM   #1
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
SS - 2012 or 2013?
Don't care much about the Nav and MyLink, but primarily wondering if the dual mode exhaust is worth getting a 2013 (and giving up what would likely be a very sweet deal on a 2012)?
Thoughts? Could it be retrofitted to a 12?
blackswan is offline   Reply With Quote
Old 08-10-2012, 02:13 PM   #2
RichTaylorSS
RichTaylorSS's Avatar
Drives: Summit White 2SS/RS
They actually have the factory dual exhaust diffuser available (shopchevyparts.com) to be retro-fitted to the 2012 (I have a 2012). If you want to go that route. I hope they can do the same with the MyLink.
RichTaylorSS is offline   Reply With Quote
Old 08-10-2012, 02:33 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Yes/no
You can install the exhaust but the car won't be programmed to open/close the valves based on engine RPM. I think for now you'll have to use a mild to wild type device "NPP in a box" to manually open/close them.
Unless someone has figured out how to program 2010-2012's
Old 08-10-2012, 03:31 PM   #4
r1coder
Evo MR to Camaro SS
r1coder's Avatar
Drives: 2012 45th SS LS3
IMO you should wait for the 2013 models only if you are looking at getting the 1LE since having the Nav and MyLink are not things you care about.
I have a 45th but after seeing the 1LE options I wish I knew beforehand...
(Still love my 45th though )
r1coder is offline   Reply With Quote
Old 08-10-2012, 03:58 PM   #5
ifiwasperfect
ifiwasperfect's Avatar
Drives: 2012 1LS 6sp /1994 Z28 auto
It all depends on your Budget buddy.
Honestly I would go for the 2013.
ifiwasperfect is offline   Reply With Quote
Old 08-10-2012, 04:22 PM   #6
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 08-11-2012, 04:16 PM   #7
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Budget's not an issue and ZL1 isn't what I really want for my DD. I would just want to drive a 13 to see how the electric steering feels, which I've been burnt on with another vendor.
There's also something nifty about getting a 2012 late in the year and going into 2013 with a 12 that has extremely low miles. In my mind (and I'm sure that's all it is), it helps offset the depreciation. If I can get a 12 for 3k or so under MSRP, I think that will be worth it and I MIGHT be able to score a 45th if there's any left (love the color).
Old 08-11-2012, 04:21 PM   #8
stikSS
9691 & 97586
stikSS's Avatar
Drives: 2010 SS, 1999 SS, 1993 Z28
Go 2013... The exhaust note is awesome... Camaro finally sounds like it should from the factory, and I talked to one of the GM reps at C5 III and he said he is almost positive that MyLink will not work in 12 or older... just because of the difference in wiring harnesses. I would go 2013 regardless of the interest in mylink or not...
stikSS is offline   Reply With Quote
Old 08-13-2012, 04:28 PM   #9
Ehmsea
Ehmsea's Avatar
Drives: 2013 2SS RS Hurst NPP
I was in the same boat as you and decided on the '13 for the DME (Dual Mode Exhaust)...TOTALLY worth it...
Ehmsea is offline   Reply With Quote
Old 08-13-2012, 04:47 PM   #10
All Star
I'm an Engineer
All Star's Avatar
Drives: 2019 Camaro 1SS 1LE
Send a message via AIM to All Star
A 2012 will be much cheaper, a new exhaust system is not worth the additional cost to me.
All Star is offline   Reply With Quote
