05-22-2016, 01:45 PM | #1 |
Drives: 2010 Camaro 2SS/RS CGM Join Date: Jul 2011
So I've got a 2010 SS ... What maintenance to consider?
Like the title says, I've got a 2010 2SS/RS. Now a 7 year old car I guess (how time flies)
I've had regular oil changes, tire replacements, brake pads, and I cleaned my vararam air filter BUT what else? Anything I'm neglecting? I've got 64,000 miles and I feel like there should be other things to pay attention to Help! Also, my AC quit working. At least it quit blowing cold. I've had to recharge it once before. Common problems in 2010's? Pat from VA Beach
Pat
2010 2SS/RS M6 3.91's, TSP Longtubes, SWG Tune, Vararam, and a heavy foot |
05-22-2016, 01:51 PM | #2 |
Drives: 2015 RS camaro Join Date: May 2016
Id say your in the mileage to start thinking about new spark plugs and in another 10-15,000 a coolant flush
05-22-2016, 01:51 PM | #3 |
Pic for mildly pleasing attention
Pat
05-22-2016, 01:55 PM | #4 |
Drives: Love the one you're with Join Date: Sep 2009
Is it an automatic? If so at 45k it should have had the fluid changed and tranny serviced. Other than that there isn't much to do but what you listed at 65k. The cabin air filter should be checked to and changed if it is dirty.
05-22-2016, 02:00 PM | #5 |
Dang ol' M6 man
Pat
05-22-2016, 02:12 PM | #6 |
We're out there
Drives: 2014 Camaro LS Join Date: Feb 2016
It wouldn't be a bad idea to check the owners manual service & maintenance section.
Who said mods aren't addictive !!
Current mods/Upgrades:K&N CAI/MRT Version 2 Axle-back Exhaust/Z28 Factory Style Spoiler Wing/Camaro ZL1 Replica Wheels(Satin Black) by Factory Reproductions/Camaro 2014-15 LS LT RS ACS-T5 Splitter(Satin Black)/"CAMARO" Caliper Covers(Matte Black)/Elite Catch Can/Window Tinting/Vmax ported TB/VTC. Future Mods/Upgrades:/Duraflex Wicker Bill Body Spoiler kit/GM-X Duraflex Side Skirts Body Kit |
05-22-2016, 02:45 PM | #7 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Clean the throttle body with a can of throttle body spray cleaner.
05-22-2016, 02:45 PM | #8 |
Drives: 2010 Camaro 2SS Bumblebee Join Date: Apr 2016
You probably want to change the timing chain....I think 60K is the recommended mileage. This is a big one.; timing chain breaks, valve job minimum, engine replacement maximum.
05-22-2016, 02:50 PM | #9 |
Timming chain on a v8 at 60K no way that is needed at that mileage. Timing belts on overhead valve motors. Yes. Not time chains at 60k.
05-22-2016, 03:36 PM | #10 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-27-2016, 06:51 PM | #11 |
376 cubic inches of fun
I have a 2010 with 50,000 miles.
The brake pads are still more than 50% Coolant was replaced at 40,000, but only because I had the AFM lifter TBS done. Otherwiswe good for 100,000 or more. I changed the diff oil because I wanted to go racing. Otherwise good for 100,000. ATF also good for 100,000 under normal conditions. I changed the air filter at 35,000. This is ahead of schedule, too, but there's a lot of pollen round here. So basically, under "normal" conditions, all you need is oil changes for the first 100,000 miles. |
05-30-2016, 01:53 AM | #12 |
change the diff oil 1qt of full synthetic 75w90 with 3oz of limited slip fluid. Some fluids come with the slip fluid in it so 1qt 3 oz
plugs and wires around 70k being the car is new to you id replace all the fluids just so you know they're good. the timing chain at 60k is for the v6 not v8 that chain is good 100k+ nice car.
05-30-2016, 08:24 AM | #13 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Diff/trans fluid and cabin filter. To a lesser extent.....plugs, coolant and brake/clutch reservoir. Really no need to"flush" anything....just drain and fill.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
