05-26-2010, 02:21 PM | #1 |
Drives: O2 GMC & 2010 camaro SS IBM 6M Join Date: Sep 2009
18" drag rims question
I got some 18inch nt05r's and i need some rims. Im lookin at the z06 rims and i dont know the exact offset that will work!! Is it 40 or 56 i think i seen also??
also anybody found the cheapest website to order them? I don't want anything fancy just something that bolts up and fits over the brakes! I would prefer black but anything cheap for now! Thanks! I know the post should be under the wheels forum but this is for drag racing and I figured y'all had more input on it
2010 camaro SS/RS Manual IBM. NEW TIME 12.24 @ 114 mph. -[B] street tires, Hurst short throw, Halltech yellow jacket intake, AR long tube 1 7/8 headers, and a tune. 12.82 @ 110 MPH 1.92 60ft ALMOST Bone Stock ONLY MOD IS Borla mufflers. |
05-26-2010, 02:28 PM | #2 |
i saw them cheap on ebay and was wondering about the stagger myself but im almost sure they will work.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s. |
05-26-2010, 02:37 PM | #3 |
Drives: 69,10 camaro 71 chevelle Join Date: Jul 2009
Im intrested also! It looks like the rear C5 18x9.5 rims are 56mm offset and the ones everyone says to use are the front C6 18x9.5s that are 40mm offset and they bolt right up. As far as the C6s I cant find anything under $250 and C5s $137. However I dont think the C5s will work without a big freakin spacer to get the right offset. Then your going to probably have to change to longer wheel studs.
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122 1969 Camaro (427 ZL-1 clone) M-22 being built 1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud |
05-26-2010, 03:54 PM | #4 |
oewheelsllc.com has good choices and prices
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
Similar Threads | ||||
Optimal Tire Size for 18" Drag Rims | RamAir02 | Dragstrip and Launch Techniques Discussion | 13 | 03-24-2010 10:15 AM |
SERIOUS QUESTION NEED ADVICE | SSCamaroKid | Wheels and Tires Talk Sponsored by The Tire Rack | 29 | 03-04-2010 08:48 AM |
drag radial question | dreeve | 4th Generation Camaros | 3 | 01-04-2010 11:41 AM |
SS - Winter 18" Rims - New brake pads won't fit | megancanada | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 12-23-2009 11:40 AM |
