01-26-2016, 05:22 PM | #1 |
cant wait till lowering springs come out...
hope they come out be4 spring cant wait to lower this car gonna look so good..
01-26-2016, 06:17 PM | #2 |
Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
Can't wait for it myself. Does your car has MRC?
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
01-26-2016, 06:23 PM | #3 |
Drives: 6th gen Join Date: Aug 2013
i get the guy from miami, but you gonna DD this car on lowering springs?
01-26-2016, 06:23 PM | #4 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
01-26-2016, 06:34 PM | #5 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
That made my head hurt.
01-26-2016, 06:50 PM | #6 |
Lol it is a basic question that one should ask before installing lowering springs. Lowering springs set the lower control arms in a different position and many times compromise, or reduce the camber curve. In an extreme case it can reverse the camber action from the desired, usually this applies to a double wishbone design, not so much with the strut design. |
01-26-2016, 07:44 PM | #7 | |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Increased handling as well as lowering the car 20mm. I think GM knows what they are doing, they wouldn't release a product that will destroy your suspension or tires. Only the import guys have camber issues. ,)
01-26-2016, 08:07 PM | #8 | |
01-26-2016, 08:07 PM | #9 | |
#becauseracecar
01-26-2016, 08:08 PM | #10 | |
#becauseracecar
01-26-2016, 08:21 PM | #11 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Talked to the guys at bmr and they won't have a street performance set up for a couple months. They are working on the drag set up and track setup first. I'm betting Eibach will have a street spring first. BMR will have about 1" to 1.2 for the rear and .75 to 1" for the front to get rid of the rake and fix the big gap in the rear.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
01-26-2016, 08:58 PM | #12 | |
I am not aware of this kit but you are correct if GM is releasing it, it most likely fall into the window of staying in the optimum range. |
01-26-2016, 09:34 PM | #13 |
SABIO
$1500 MSRP
01-26-2016, 09:36 PM | #14 |
SABIO
Ohlins has a adjustable shock for the 2016. Posted a short video clip somewhere here of them talking about it
Edit: sorry, I originally said Eibach. It's Ohlins with the adjustable
