05-31-2014, 12:22 PM | #1 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
Brakes before cruise?
So I was talking to my brother-in-law and telling him about by sem-annual inspection on my car, and also mentioned the couple of cruises through the mountains this summer. He suggested I get new brake pads before driving on these cruises.
The brakes from the dealership inspection are at 5mm (roughly 6/32) on the front, in their yellow range, and 7mm (roughly 7/32) on the rear, in their green range. I've had the car 4 seasons now, and have never had the brakes done. With the cruise coming up on June 14th, should I get new brake pads now? Just the front? No need as they are still fine? Thanks in advance!
05-31-2014, 05:54 PM | #2 |
Drives: 2011 RS/2SS Join Date: Jun 2011
What do the rotors look like? Your pads should be fine........depends on how you think you'll drive??? Not sure of the KM on your car either??
05-31-2014, 08:28 PM | #3 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
How many K's?
05-31-2014, 08:40 PM | #4 |
In The Circle
This what I run in Pumpkin slightly more aggressive then stock. If you do your own work and the rotors are not chewed up and they shouldn't be. I would just give then a rough up with sandpaper and and throw a set of new pads in. $260 US for the the set plus tax and a bus ride and your good to go.
05-31-2014, 08:55 PM | #5 |
In The Circle
These are what I use on the road course. Very aggressive, dirty, noisy and hard on rotors, but they WOOOOOW Pumpkin down in a hell of a hurry.
06-01-2014, 12:42 AM | #6 |
Sorry, sons graduation banquet tonight! Just getting back.
I have 64k km on the car. I have no idea what to look for to inspect the rotors. I can only say they were not mentioned at all in the semi-annual. I don't really drive all that aggressively. It's a daily driver though. I hate the brake dust from the oem pads! Forever cleaning the rims! Would those hawks produce less dust?
06-01-2014, 03:01 AM | #7 | |
In The Circle
06-01-2014, 09:10 AM | #8 | |
I personally don't like to install new pads on a rotor that hasn't been turned or replaced - unless the rotor is in very good shape. This may cause uneven or premature pad wear. Hope this helps! |
06-01-2014, 10:35 AM | #9 |
LongTimeLurker
Drives: 2011 SIM 2SS/RS Convertible L99 Join Date: Dec 2012
I forget the KM on my car when I had the brakes replaced this winter. I guess at around 42-43k. I am assuming that they were the original pads on the car. I had the pads replaced at a GM deal with the OEM pads.
I used to have the "never ending battle" with brake dust, however I have not had the same experience with these new pads. Dust is really really low. Normally I detail the car Thursday evening, and park it. After work on Friday I would go to the Car show in Kingston about 30KM away. Before I would have to take a microfibre towel and some waterless wash to the rims after I had parked at the show. Since I got these new pads, I have been able to drive and park and the rims look fine. I ran my finger on the rim this past Friday and it did not leave a line and i had very little brake dust on my finger. Also, PREVIOUSLY I would detail the car and go for a tour with the car. Maybe a 200-300km cruise. Next day the car would still be more or less spotless (besides bugs on the front) but my tires and RIMS with be absolutely filthy. So bad that I would end up just washing the rims/tires. I have done that a few times this season and the rims were more or less fine. I just waited to do the rims when the rest of teh car needed a bath. So far (to me), the new pads preform just as good if not a bit better then the stock pads and I do not get nearly the same amount of brake dust I got before.
2011 2SS/RS |
