Old 08-07-2017, 07:58 AM   #1
Gossamer
Drives: 2012 Camaro Convertible
More oil filter questions
Searched couldn't find a definitive answer
3.6 V6.
Oil filter Delco shows
PF2129, PF2129G and PF2130 all seem to fit this motor.
Manual says 2129 but I see some people here use the 2130.
thank you for some insight
Getting ready for my first change on this car and want to make sure I've got the right one. Can't always find the Delco's easy around here and not Fram fan.
Gossamer is offline   Reply With Quote
Old 08-07-2017, 11:09 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Yeah I've always wondered what the difference if any between the 2129 2130 was. Then they came out with the 2129G. I picked up a 2129G and will use it on my next oil change.
Also, don't forget to change the o ring on the oil filter housing lid.
Lil' Nasty is offline   Reply With Quote
Old 08-07-2017, 12:13 PM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I believe the 2130 comes with the o-ring and the 2129 doesn't. IDK why that would matter... but I think that's the only difference.
Not sure what the G series would be about.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is online now   Reply With Quote
Old 08-07-2017, 01:14 PM   #4
Gossamer
I was wondering if the 2129G came with gasket when the regular 2129 didnt?
But then why is there still a 2130???
Great job with these motors, silly as setup with filter designation and no easy to way to find out what one isnt?
The plus side, amazon has 5qt jugs of mobil 1 for 22.xx right now so I ordered 4 jugs. Just need to find the right filter. When 3 different ones 'all fit' I got confused
Old 08-07-2017, 01:58 PM   #5
ChibiBlackSheep
Maybe the 2129G will just dissolve both the 2129 and 2130 eventually.
Personally I use these filters: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just love my Wix. Use them in every vehicle.
Old 04-21-2018, 12:35 PM   #6
awdmofo
V6 banger
awdmofo's Avatar
Drives: 2016 Lexus CT200H
Anyone ever figure out what the difference is? at oreillys its like 50cent difference lol.
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy)
2013 LS 6-speed (SOLD)
Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP
Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA.
awdmofo is offline   Reply With Quote
Old 04-21-2018, 12:52 PM   #7
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I have a 2014 Camaro LFX, AC Delco PF2129 is what was called for. On all my collector cars I only used K&N filters. When I first purchased the Camaro I sent to Summit Racing and order 2 K&N filters (PS-7003). OMG was I taken back when they arrived. When I removed the AC Delco I saw that both ends were metal with paper filament between the ends. The K&N even has paper ends! NEVER again. Then one day at O'Reilly's I found the MicroGard MGL57090 filter was half the cost of the AC Delco yet the EXACT filter according to numbers on the filter ends!
Deputy347k9 is offline   Reply With Quote
Old 04-21-2018, 01:32 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Have you ever considered that the filter media has been basically PAPER since the beginning? Something like a coffee filter paper only maybe a little bit stronger? Fiberboard end caps attached to paper seems like we might be over-reacting to the cardboard end caps. Just something to think about.
Old 04-21-2018, 02:21 PM   #9
KillboyPowerhead
Drives: 2015 Z/22
Just to comment on a post above: the 2129 does indeed come with an o-ring.
KillboyPowerhead is offline   Reply With Quote
