05-07-2013, 03:04 PM | #1 |
Drives: 2011 camaro synergy Join Date: Sep 2012
A note for those changing you're own tires
Most of you are probably smarter then this,so I write this for anyone as dumb as me. Having the 21" P-zeros I decided to call The Tire Rack for new rims and tires to use for winter. When the tires arrived mounted,balanced and ready to go I changed them over myself.All was well. The Pirelli Sporpion Ice and Snow tires worked great. Two weeks ago I changed back over to the P-zeroes. Several days later I had to take a several hundred mile trip. I noticed a slight vibration.Yesterday I took it in for an oil change and had them check my tires out. When I changed back to the P-zeroes,a spacer on the right rear had stayed stuck on the car.I didn't even know that it had a spacer.It took the tech.about 15 min. to pry the spacer off the car. Had I gone much further it could've caused damage to my stock rim.Lesson learned!!!!
05-07-2013, 03:25 PM | #2 |
Those spacers are called hub-centric rings. I'd bet that over half of vibration problems with aftermarket wheels can be traced to these things. Or lack of most of the time.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
