#Camaro6
Old 12-09-2015, 10:33 AM   #1
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
Skip-shift eliminator carry over?
now... I don't know much about the mechanical aspect of cars, and I'm not gonna pretend I do, but I have been driving "spiritedly" since I was about 12-13 (IROC-Z FTW!!!!) and was a bit upset when I found out the skip shift crap is going to be part of the gen6.. upset, but not surprised. that skip shift crap makes it a pain when trying to drive relaxed but still control when I shift.
so my question is this: does the skip-shift eliminator thing used on the gen5 compatible with the gen6? I don't want to have to wait a long time for a new one to come out.
Techn9cian805 is offline   Reply With Quote
Old 12-09-2015, 11:04 AM   #2
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
^5
Originally Posted by Techn9cian805 View Post
now...
What he said
SkipNWis is offline   Reply With Quote
Old 12-09-2015, 01:47 PM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
honestly I never hit it in my zl1. all you have to do is rev over like 2500 rpms in first gear you will never hit.
I bought the cable but I never installed it. It is really driving style related the only way it ever activates is if you are really grandma driving the car. you adjust you driving style pull 3k in first gear it will never ever activate.
I think they are still using the 6060 trans so i assume the last gen skip shift would work.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 12-09-2015, 02:40 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
It really sucks in stop and go traffic. Before I got the CAGS eliminator on my 4th gen I would just let it slip into neutral for a second and then it would have no problem going into second. After a few days of doing it it was second nature to where I still did it subconsciously sometimes even after the eliminator.
Eric SS is offline   Reply With Quote
Old 12-09-2015, 10:30 PM   #5
SkipNWis
SkipNWis's Avatar
OK VENDERS you should be ON this Be the first to start selling them
Old 12-10-2015, 12:46 AM   #6
BrianInJackson
Drives: toyota mr2
I am not going to be modding this car much... but this is probably on the list. I want to decide when to shift and what gear. Spent a little time with a skip shift and it didn't seem to get in the way, but... Not sure it is something I want everyday. Wish you could turn it off... Like rev match. Or adjust when it kicks in via the drive mode selector.. How about it only working in Snow/Ice, and Touring mode.. Sport and Track mode would disable it. Good idea??
BrianInJackson is offline   Reply With Quote
Old 12-10-2015, 01:14 AM   #7
Techn9cian805
The BEAST
Well, you will still be able to go from 1 to 4th on your own, with the eliminator installed, you'll still get the notification that you "can only shift from 1st to 4th" but be able to ignore it.
Old 12-10-2015, 03:18 AM   #8
cartem2
cartem2's Avatar
Drives: Nightfall Gray 2LT RS
I am glad thats just on the SS!! It would make since to have a track mode that disables it, probable a regulation that doesn't allow them to add that. I'm not very familiar with them as I've always driven the V6s heh. Seems like an anoying feture tho that's for sure.
My Build Journal, Review, and Photos: Here
cartem2 is offline   Reply With Quote
Old 12-10-2015, 09:22 AM   #9
Eric SS
#becauseracecar
Eric SS's Avatar
While it would be nice, there would be no reason for GM to have it disabled in track mode since it will not activate during spirited driving. Only normally coming off the line from a stop and shifting at a normal rpm. If the car is under heavy acceleration or higher rpms, it doesn't activate.
Old 12-10-2015, 10:58 PM   #10
SkipNWis
SkipNWis's Avatar
COME on VENDORS ????? Somebody has got to want to sell them ?????
Old 12-11-2015, 01:43 AM   #11
bhavyas
bhavyas's Avatar
Drives: 2016 1SS Yellow
Wow... So I was wrong in thinking this comes into effect when you actually rev harder in the first gear.. I thought because you rev harder... ur engine has to work more ... meaning more fuel is consumed.. and to compensate for that .. it asks you to shift to 4th.. thereby dropping the revs and thus reducing the work the engine does... hmmm .. so it seems it kicks in when u r driving leisurely so that you can kick out more miles per gallon.. is this correct?
1SS,Yellow,Gray Wheels,Black bow ties,NPP.
bhavyas is offline   Reply With Quote
Old 12-11-2015, 02:31 AM   #12
HDRDTD
I don't remember the exact conditions skip shift comes into play but it's something on the order of the car being at a certain operating temp, the throttle being at a certain low percent when you shift from 1st.
Basically you have to have the car warmed up, and be accelerating at a very slow rate when you shift out of 1st. It does not totally prevent you from shifting to 2nd although the shifter 'will' move over to drop into 4th.
All you have to do is shift into neutral for a split second, then go ahead and put it into 2nd.
Old 12-11-2015, 02:35 AM   #13
HDRDTD
Gear Select - Skip Shift (CAGS)
To ensure good fuel economy and compliance with federal economy standards, SECOND and THIRD gear are inhibited when shifting out of FIRST gear, under the following conditions:[*]Coolant temperature is above 50°C (122°F)[*]Vehicle speed is 20 - 29 km/h (12 - 19 mph)[*]Throttle is opened 35 percent or less
Old 12-12-2015, 10:19 AM   #14
DevonK
DevonK's Avatar
Drives: TBD
In another thread I calculated the RPM you need to hit in first to avoid the skip shift - its damn low, barely over 2000 IIRC....
DevonK is offline   Reply With Quote
