12-04-2013, 10:00 PM | #1 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
will a sealant like zaino leave white residue on stripe edges?
have a black SS now and used Collinite 476 on the paint and stripes but it leaves alot of white residue on the stripe edges, even took a brush to the edges to take the residue off but the next day it was back after a light rain that night. thinking about switching to sealant full time or at least just doing the striped area with a sealant exclusively. anyone have recommendations?
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
12-04-2013, 10:37 PM | #2 |
You should just tape off the stripe edges.
Sent from my HTC One using Tapatalk 2
[B]
12-05-2013, 04:43 PM | #3 |
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
Is taping off needed if using a WOWA sealant like Prima Hydro MAX?
Thanks.
12-05-2013, 08:26 PM | #4 |
well I have gloss stripes so I waxed paint and stripes together. Guess I am looking for a sealant that I can put over the stripes without white residue afterwards. ye I could tape off the stripes but would rather use a product that leaves no residue if it exists. in the spring I will strip all the wax off and start doing the stripes with sealant only if I have to and wax the rest of the car as usual.
12-05-2013, 08:29 PM | #5 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
I'm using a sealer gloss as well, and I get the same problem. I just keep a towel handy and wipe off the spots when I see it. Plus it's a pain to wax the piece in between the edge of the stripe.
12-05-2013, 08:58 PM | #6 |
Drives: 2011 Red 2SSRS A6 Join Date: Jan 2011
It's residue from the wax getting caught on the lip of strips, it doesn't matter if its a wax or sealant you will still get the residue. Like CamaroDreams said the only solution is to tape the edge of the strips.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
12-08-2013, 02:51 PM | #7 | |
Drives: 02 SS 35th LE Vert, 2013 ZL-1 Vert Join Date: Jul 2012
12-09-2013, 05:28 PM | #8 |
I thought I remember reading that some where and was looking for confirmation that doesn't leave alot of residue. thanks!
12-10-2013, 10:26 AM | #9 |
Drives: The shiny ones. Join Date: Mar 2010
Its not so much residue as it is an excessive buildup along the edge. Regardless of the product brand/type - when you get a thick buildup of product, more than would be considered normal thickness anywhere else on the vehicle you'll have a visual issue. Either a chalky residue, haze, etc.
Its fairly easy to get a pretty big buildup of stuff along the edges of the stripes, the question is if you prefer to remove it after the fact or prevent it in the first place. Either option is going to require you to invest some amount of time. |
