01-28-2022, 09:20 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Only thing cheap about speed engineering is the price
Thats my take anyway. Just put a set on. They feel of quality and strong. Fit is very good seems to me. These are 2 inch. No part of them needed to be bent or any of that nonsense.
What I notice is these have a very similar pipe configuration like the kooks. I bet theirs probly no power difference between these and kooks but I will never know for sure. What I like to see as equal length as possible in the pipes. Just started it up in the garage, Try to drive it in a few days. I put 2 of the 3in vibrant ultra quite resonator's on. That is totally custom to get them to fit and mount up to the stock exhaust. It was a lot of work. 3 of the ends of the resonators had to be cut off realigned and welded back on. Excuse the red paint lol its the only high temp I had around. I will be using heat shield products to put on the headers up top for heat control. They slid in pretty good from the bottom drivers side easy peasy passenger side had to remove the starter to work it on that side. The starter shield fit right back on and was able to slide a piece of heat shield between the starter shield and the header. Ill post some sound clips in a few days when its completed. I bought button head bolts on amazon for the steering but was not needed. lots of clearance. The number 5 plug is tight. Had to use a wrench on the spark plug tool. have to have a 45 degree boot as well the stock wire will not work on that cylinder . did not try on any others. Questions? ask away. |
01-28-2022, 09:22 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
i like mine. the only thing i don't like is that i'll have to remove the pass side header to replace the starter. the speed engineering headers are great. the x and mid pipes are junk.
2016+ camaro: everyone’s first car
01-28-2022, 09:28 PM | #3 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Looks really good. I was thinking of getting those and decided to get TSP headers because the price is half the price of kooks which I had on a previous build. I would recommend you get a set of Spark Plug Wire Thermal Heat Protectors on those wires.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-28-2022, 09:28 PM | #4 |
Just for every one the button head bolt is m8 by 1.25 by 25 mil long. Not needed with this 2 inch set
01-28-2022, 09:29 PM | #5 |
Thanks I will be putting the heat shield on the header for that and underhood temp.
01-28-2022, 09:37 PM | #6 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
My question would be: where are the savings? These headers cost about $40 or $50 bucks less than TSP headers of the same size depending on where you shop and what time of year you buy. I would understand the appeal if they were at least $100 bucks cheaper than everyone else's headers, but they are not. So again, why?
01-28-2022, 09:47 PM | #7 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
O2 sensor placement means those sensors will fail fast and often. Is that common on LTH ?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
01-28-2022, 10:07 PM | #8 | |
I paid 511 with stock oem gaskets bolts and 2 afr extenders shipped to my door. Headers are 449 shipped |
01-28-2022, 10:07 PM | #9 |
01-29-2022, 07:09 AM | #10 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Ive had them on for years, really solid part. The xpipe could do with better fitment. But parts made great power na
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
01-29-2022, 07:16 AM | #11 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
I had them on my C7, loved the price, performance and they fit really well. I also ran the longer plug wires which give you a little more to move the wires around and keep them off the headers. I did replace the original band clamps which were much narrower with 4" band clamps as I had a couple of exhaust leaks.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
01-29-2022, 07:04 PM | #12 | |
Drives: 2018 1SS 1LE Join Date: Dec 2012
01-29-2022, 11:36 PM | #13 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
It's nice to know that nobody HAS to spend $1800 on a pair of well fitting good headers. And it's good to know that whether you spend $500, or $500 + and extra $1300, you will get the same performance. Now I'm not knocking Kooks or ARH or any of the other top brands. But I think there are enough examples out there to prove that some of these prices are wayyyy over the top.
01-30-2022, 07:00 AM | #14 |
Drives: 6th gen Join Date: Aug 2013
