01-16-2010, 06:28 PM | #1 |
Drives: Cargo van. Join Date: Jul 2009
Easy 100lb diet.
Weighed my car on 21 Jul 09 bone stock and it was 3860 with a 1/2 tank of gas and no other stuff inside...ie floor mats, trunk liner inflator ect ect.
Well I took off both engine covers, did the muffler delete, resonator delete (l99) put in an x-pipe, went with catted long tubes by dynatech, rotofab cai. I weighed it today with a some junk in the car, floormats trunk liner stuff in the center console and glove box and it weighed 3760 with just over a 1/4 tank. Thats an easy 100 just from pretty much exhaust work. Next I will take out the hood and trunk pads, the trunk flooring and the heat shields and weigh it again, probably around an 1/8tank as thats what I would like to be with at the track. Oh and emptied the washer tank too, but I dont remember if it was full or not last time. Eitherway still an easy 100lbs. |
01-16-2010, 07:08 PM | #2 |
I used to be Dragoneye...
Thanks for posting your results, Rodimus!
The "gas mod" accounted for about ~28lbs...so the rest of the mods made quite an impact!! I imagine you could get another 50-75 lbs or so by swapping the wheels and rotors for lighter units. |
01-16-2010, 07:30 PM | #3 |
Drives: 57Chevy TrailblazerSS 73Camaro Join Date: Aug 2009
the difference between 1/2 and 1/4 tank of gas is probably your biggest weight difference. A gallon of gas weighs over 6lbs.
01-16-2010, 07:42 PM | #4 |
Drives: C6 Zed-oh-six Join Date: May 2009
I weighed my mufflers at New Era when I had my SLP LM put on and they were incrediably heavy, I forget how much weight I dropped but it was like 30#s or something just by deleting the mufflers
01-16-2010, 07:50 PM | #5 | |
nice! good info.
01-16-2010, 08:01 PM | #6 | |
But it goes to show you can drop weight pretty quick if you need to. I weighed it both times on CAT certified scales. $9.00 a pop. |
01-16-2010, 08:06 PM | #7 | |
Boosted Moderator
I can picture a long haired tabby putting a paw on the scale and saying .... yup, they're accurate...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
01-16-2010, 08:07 PM | #8 |
I've been meaning to give them a call and ask exactly how much lighter weight they are...If I had a car, I'd be torn between SLPs wheels or the BBS wheels they popped on Leno's car.
01-16-2010, 08:08 PM | #9 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Thanks for the info, If you can afford to do coilovers there is 50lb and two part rotors is 20lb, So what do you want to get to,? and a good CAI is 8lb less.
01-16-2010, 08:08 PM | #10 | |
I forgot I threw on a yank converter too. Its a bit smaller than stock. |
01-16-2010, 09:31 PM | #11 | |
Drives: Hyundai Sonata Join Date: Feb 2009
Also, I'd be careful which heat shields you remove. I doubt they weight a whole lot, and I'd be weary of removing functional, protective components as opposed to cosmetic components like engine covers. |
01-16-2010, 10:16 PM | #12 |
Drives: X-15 Velocipede Join Date: Mar 2008
So, muffler delete = excellent weight loss AND lower restriction (HP). noice
01-16-2010, 10:31 PM | #13 |
Will do.
Not to mention a beautiful sound! |
01-16-2010, 11:15 PM | #14 | |
Similar Threads | ||||
Installing Bluetooth Onstar (OEM) For Hands Free Phone (Easy, Cheap) | VT2CA | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 612 | 05-21-2020 02:14 PM |
Easy to change the cluster from US units to metric? | yockey | 5th Gen Camaro SS LS LT General Discussions | 20 | 08-27-2018 09:54 AM |
Camaro straight pipe, a quick and easy exhaust mod (videos) | 2010 SS RS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 234 | 12-18-2017 10:06 AM |
Mini Bikes / kids today got it easy | 2ndgenz28 | Off-topic Discussions | 8 | 11-23-2009 10:36 AM |
