ADM PERFORMANCE
Old 03-15-2017, 08:56 PM   #1
mwillems
mwillems's Avatar
Drives: 2012 Camaro ZL1
My Dashlogic Config (XML file, just import it)
Hey all,
***** EDITED --- NEW VERSION BELOW *****
Those of you with a Dashlogic unit and a ZL1: here's what I just did for my 2012 ZL1. 8 pages of displays on HUD, DIC and Radio, roughly organized by type:
Page 1 - temps
Page 2 - Engine health
Page 3 - Engine health 2
Page 4 - Fuel
Page 5 - Performance
Page 6 - Driver Operation
Page 7 - Driver Operation
Page 8 - Misc
Here's the XML. Write it to a file and import that file. Done.
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<dashlogic_configuration_data version="1">
<hud revision="1">
<page_definition page_number="1">Amb/Int {30: 3.0} {1020: 3.0}C
Coolant {2: 3.0}C</page_definition>
<page_definition page_number="2">MAP {8: 5.1}kPa
MAF {16: 5.1}g/s</page_definition>
<page_definition page_number="3">TQ {30005: 3.0} {1014: 3.0} lbft
TQ Retard {1018}%</page_definition>
<page_definition page_number="4">Fuel: {30003} l/h
Press {2503} kPa</page_definition>
<page_definition page_number="5">BST {30001: 4.0}kPa
PWR {30004: 4.0}HP</page_definition>
<page_definition page_number="6">YAW {3023} dg/s
LAT.ACC {3019}g</page_definition>
<page_definition page_number="7">Throt: {1022: 3.0} {1023: 3.0}%
Clutch {1032: 3.0}%</page_definition>
<page_definition page_number="8">BATT {10101}V
EVAP {28}%</page_definition>
</hud>
<dic revision="1">
<page_definition page_number="1">Pres {1002}kPa
Temp {1004: 3.0}C</page_definition>
<page_definition page_number="2">Fuel Trim:
{4: 4.0} {6: 4.0}%</page_definition>
<page_definition page_number="3">Misfires: {1007}
Knock Ret {1001: 4.0}%</page_definition>
<page_definition page_number="4">Fuel {23: 3.0}%
{30023: 5.1} l/100km</page_definition>
<page_definition page_number="5">TRQ {1015: 3.0} lbft
RPM {10: 4.0}</page_definition>
<page_definition page_number="6">Steer {3024}
Gear: {30025}</page_definition>
<page_definition page_number="7">{3009:03.0} km/h {3011:03.0}
{3013:03.0} km/h {3015:03.0}</page_definition>
<page_definition page_number="8">O2&lt;CAT {19: 6.1}
O2&gt;CAT {21: 6.1}</page_definition>
</dic>
<radio revision="1">
<page_definition page_number="1">Oil Life Remain {1006}%</page_definition>
<page_definition page_number="2">Gear {30025}</page_definition>
<page_definition page_number="3">Timing {13} deg</page_definition>
<page_definition page_number="4">Fuel Alc {27}%</page_definition>
<page_definition page_number="5">Speed {11: 3.0} km/h</page_definition>
<page_definition page_number="6">Barometer {24: 5.1} kPa</page_definition>
<page_definition page_number="7">Speed {11: 3.0} km/h</page_definition>
<page_definition page_number="8">Lambda Command {29}</page_definition>
</radio>
</dashlogic_configuration_data>
Photographer/Engineer/Radio Amateur
http://www.michaelwillems.ca
mwillems is offline   Reply With Quote
Old 03-19-2017, 02:12 PM   #2
mwillems
mwillems's Avatar
Actually, see new entry below. I updated it after some test driving!
Old 03-19-2017, 02:21 PM   #3
mwillems
mwillems's Avatar
NEW VERSION (after test drive);
[HTML
<hud revision="1">
<page_definition page_number="2">MAP {8: 5.1} kPa
MAF {16: 5.1} g/s</page_definition>
<page_definition page_number="3">Tq {30005:03.0}/{1014:03.0} lb/%
Tq Retard {1018:03.0}%</page_definition>
<page_definition page_number="4">Fuel: {30003:03.0} l/h
Press {2503:03.0} kPa</page_definition>
<page_definition page_number="5">Boost {30001: 4.0} kPa
Power {30004: 4.0} HP</page_definition>
<page_definition page_number="6">Yaw {3023: 5.0} deg/s
Lat.Acc {3019: 5.1} g</page_definition>
<page_definition page_number="7">Throt {1022:03.0} {1023:03.0}%
Clutc {1032:03.0}%</page_definition>
<page_definition page_number="8">Batt {10101}V
EVAP {28:03.0}%</page_definition>
</hud>
<dic revision="1">
<page_definition page_number="2">S.T. Fuel Trim:
{4: 4.0}% {6: 4.0}%</page_definition>
<page_definition page_number="4">Tank {23: 3.0}%
<page_definition page_number="5">Trq {1015: 3.0} lbft
<page_definition page_number="8">O2&lt;Cat {19:06.1}
O2&gt;Cat {21:06.1}</page_definition>
</dic>
<page_definition page_number="1">[1-Temps] {30}C</page_definition>
<page_definition page_number="2">[2-Health] Gear: {30025}</page_definition>
<page_definition page_number="3">[3-Health] Timing: {13:03.0} deg</page_definition>
<page_definition page_number="4">[4-Fuel] Fuel Alc {27}%</page_definition>
<page_definition page_number="5">[5-Perf.:] {11: 3.0} km/h</page_definition>
<page_definition page_number="6">[6-Ops] Barom. {20000:05.1} hPa</page_definition>
<page_definition page_number="7">[7-Manoeuvring] {11: 3.0} km/h</page_definition>
<page_definition page_number="8">[8-Misc] Lambda Cmd {29}</page_definition>
</radio>
<alarms revision="1">
<alarm alarm_number="0">
<enabled>1</enabled>
<display_mask>1</display_mask>
<flags>0</flags>
<app_flags>0</app_flags>
<duration>1</duration>
<beep_type>2</beep_type>
<display_text>*** RPM Limit! ***</display_text>
<condition_expression>(pid(10) &gt;= 5500)</condition_expression>
</alarm>
<alarm alarm_number="1">
<display_mask>4</display_mask>
<flags>2</flags>
<display_text>Speed {11:03.0}</display_text>
<condition_expression>(pid(11) &gt;= 120)</condition_expression>
</alarm>
</alarms>
<user_calc_pids revision="1">
<user_calc_pid pid_number="0">
<valid>1</valid>
<flags>0</flags>
<default_precision>1</default_precision>
<acronym>BAROH</acronym>
<units>hPa</units>
<name>Barometer in hPa</name>
<calculation_expression>(pid(24) * 10)</calculation_expression>
</user_calc_pid>
</user_calc_pids>
[/HTML]
Old 03-19-2017, 02:53 PM   #4
mwillems
mwillems's Avatar
NEW VERSION HERE:
All improved version here:
http://www.camaro5.com/forums/showthread.php?t=488268
Cheers,
M
Old 07-15-2017, 04:05 AM   #5
N2O
N2O's Avatar
Drives: Camaro ZL1
i also bought a dashlogic and i can only see my PIDs in the HUD. It is not showing in DIC or the radio? BTW i have a 2013 camaro ZL1
2013 Camaro ZL1 - CAI intake
N2O is offline   Reply With Quote
Old 07-18-2017, 02:12 AM   #6
ZL1-Camaro
Drives: Black M6 2013
You have to turn your dic to nav. It is for onstar nav if you do not have the nav option then radio will not display. I read that on the site forum. I also have dashlogic on a 2013 without nav. It is true.
ZL1-Camaro is offline   Reply With Quote
Old 07-18-2017, 08:24 AM   #7
N2O
N2O's Avatar
Drives: Camaro ZL1
I dont have navigation and maybe thats the reason my PID's are not showing in the radio or DIC. My car is also a 2013.
Old 07-19-2017, 01:38 AM   #8
ZL1-Camaro
They will show on the DIC You just have to scroll till you find it, I think in information menu not sure but even with nout nav onstar has an option on the DIC choose it and PIDs will show.
Old 07-19-2017, 03:31 AM   #9
N2O
N2O's Avatar
Drives: Camaro ZL1
i tried everything,switched the version of dashlogic to 1.15 also and reset the cluster fuse too. Not showing. Then also got the HUD and Radiao off and only the DIC on from the dashlogic vehicle config menu but still its not showing on DIC or radio. Only shows on the HUD.
Old 07-19-2017, 04:29 AM   #10
ZL1-Camaro
I will drive my car tomorrow and I will make a detailed description of how I get to show on My DIC, I know that it will work.
Old 07-19-2017, 07:24 AM   #11
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
If Dashlogic PIDs are showing on the HUD then you don't have the HUD set to off. If the HUD is set to Off, then when you start the car the HUD should display "Palmer Performance HUD OFF" then go into normal HUD display. What does your car display in the HUD on startup?
ZL1-Camaro is correct you do not need Nav, you only have to have the DIC set to NAV.
Press the Menu button on the turn signal stalk until it displays Navigation with a symbol
in the DIC. Then go thru the InVehicle dashlogic config settings on turn the DIC on.
camguynj is offline   Reply With Quote
Old 12-04-2017, 11:41 AM   #12
DuskssJP
DuskssJP's Avatar
Drives: 2013 Camaro 2SS/RS Dusk Edition
Anyone know where to find this info but for an SS?
2013 2SS/RS Dusk Edition BBK long tubes w/ Hi-Flo cats, NPP Exhaust, K&N Blackhawk CAI, Bilstein shocks & struts, Eibach Pro lowering springs, R1 Concept Eline Cross Drilled & Slotted Rotors... more to come
DuskssJP is offline   Reply With Quote
Old 12-04-2017, 09:21 PM   #13
camguynj
camguynj's Avatar
SS Dashlogic settings same for ZL1 ...Dashlogic doesn't go by model types, it works the same for all models. Of course if your model doesn't have a HUD you don't have to set any HID settings.
Old 12-05-2017, 06:14 PM   #14
DuskssJP
DuskssJP's Avatar
Great thanks for the info!
