HURST
Old 07-18-2017, 04:10 PM   #1
ZL1C7
ZL1C7's Avatar
Drives: 2015 ZL1/1970 GTO 455HO
ZL1 NPP 3-Way Exhaust Controller?
ZL1 NPP 3-Way Exhaust Controller? Adm does not sell them any more. Anybody have the contact info on another vendor who still makes them?
ZL1C7 is offline   Reply With Quote
Old 07-18-2017, 04:20 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
Forza's 3 way controller. i have it and super easy to install
http://www.forzacomponenti.com/exhau...troller_d.html
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 07-18-2017, 04:51 PM   #3
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
You can buy all the parts on Amazon for like $30 tops and do it yourself if you're handy.
NVRL8 ZL1 is offline   Reply With Quote
Old 07-18-2017, 07:13 PM   #4
ZL1C7
ZL1C7's Avatar
Awesome.. Thanks
And.. NVRL8...You happen to have a diagram?
Old 07-18-2017, 07:28 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I bought this one as well. Works great just make sure you wire it to turn off with the ignition switch or you'll get battery drain if the car sits for any length of time.
Mods:
Old 07-19-2017, 10:16 AM   #6
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
Originally Posted by ZL1C7 View Post
Awesome.. Thanks
Here is a thread that has a ton of info,
http://www.camaro5.com/forums/showth...&highlight=NPP
the PDF's have quite a few good repair manual drawings in them.
If you want to run the NPP using the home link button, just buy a remote control relay and substitute the toggle for the relay. Program the Home link the same way as you would a door opener
Relay wiring.pdf
Old 07-19-2017, 11:39 AM   #7
608RS
608RS's Avatar
Drives: 2015 2ss
yup, or just toggle the power button on the box itself when the car will be stored and not started for more than ~one week at at time.
did you wire this one to an ignition switch? did you have to run a wire into your cabin?
