Old 12-11-2012, 04:34 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Sway bar setting
I'm wanting to try to the stiffest setting on the front of my sway bar. From what I remember it was the inner setting that would be the stiffest. Based on this picture it would be setting #1. Is that correct? Just double checking before making the change.
Build Journal
Old 12-11-2012, 05:19 PM   #2
Camper
Banned
Drives: 10' 2SS LS3 M6
generally the hole closest to the bar itself is the stiffest
Camper is offline   Reply With Quote
Old 12-11-2012, 06:53 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
The stiffest is the hole that's the shortest distance to the bushing- on your LSR it kind've looks like a draw, in that picture anyway, between #2 and #3.
But I'm betting on #3 per the manufacturer!
Old 12-11-2012, 06:59 PM   #4
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
you are correct
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 12-11-2012, 07:51 PM   #5
Enough
Drives: 2013ZL1
1 is the stiffest, shortest lever arm.
Enough is offline   Reply With Quote
Old 12-12-2012, 01:30 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
This is correct hole number 1 is definitely going to be the stiffest setting on your sway bars. Like everyone else said the shorter the distance is between the end link mounting position and the body of the sway bar itself the stiffer it will be.
Old 12-12-2012, 03:23 PM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Getting ready for your new rear bar?
Old 12-12-2012, 05:06 PM   #8
caverman
caverman's Avatar
Yep....
Just need the lower control arms to get here and hope to be ready to go after that.
Build Journal
Old 12-12-2012, 05:14 PM   #9
JusticePete
They just arrived!!!
Old 12-12-2012, 06:49 PM   #10
Ventmaster
Ventmaster's Avatar
I stand corrected- and thank goodness my front bar is on the middle position also, but I'm still not seeing how hole #1 is the closest to the "body of the bar".
Can ya dumb-it-down a little more for me? Thanks!
Old 12-12-2012, 07:01 PM   #11
JusticePete
Hole #1 is 'inside the bar while hole #3 is outside the bar.
It is all referenced to the length of the side arm on the bar. The shorter the arm the less movement there will be. When you were a kid on a teeter totter the fulcrum is in the middle. You can exert the most leverage from either end of the board, but the least amount of movement will always be closest to the fulcrum.
Here comes overkill on the subject.
INTRODUCTION
This paper is a condensed version of a Pedders training seminar. It was designed to give everyone a greater understanding on sway bars and why Pedders uses the 3 Solution Packages that we offer. It also was intended to at least partially explain the testing and R&D that Pedders does, when introducing a new product. Understanding how Pedders does their checking, we then tried to relate this to other manufacturers, which is challenging because sway bars are all over the map. This is accomplished by making specific comparisons from one brand to another, and charting all of them together in a common format for instant comparison. The purpose of this format is not to prove Pedders has a better setup, but is designed to compare Pedders with other setups, and let you make the decisions yourself. With basic calculations that will be given, you can do your own math and your own comparison. Also, the paper is designed to explain the 6 most common factors that determine overall strength, and the individual influences they offer.
I do not have an engineering degree, but I do have a degree in Automotive Technology and Automotive Vocational Education. All the data I have used is clearly available, and with the help of a couple of structural engineers that I know, helped with making the terms simple as can be made to understand. But Pedders in Au. has tons of engineers and a huge R&D department. Add their design work, with actual comparative testing, we feel we have come up with what we feel are the optimum solutions. Watch the videos of the Pedders Camaro, which will prove what we know.
Thank you
Sway Bars! What Are They Good For??
Everyone recognizes the benefits of sway bars, but that is where the knowledge and understanding stops for the majority of the auto enthusiasts. There is a lot of misinformation out there , including unsubstantiated improvement gains, which leads to a lot of incorrect assumptions. Therefore, sway bars are the most misunderstood suspension component on your vehicle. This educational document will hopefully help you better understand sway bars, with the hope you can gain the knowledge in determning the best sway bar for your driving needs.
Why the need for knowledge on sway bars? The answer comes from another question:
Why do People choose a particular sway bar brand?
1. Word of mouth
2. Forum posts
3. Reputation of manufacturer
4. Marketing by the manufacturer
5. Price
6. Size of bar
7. Hollow bar to remove weight
8. Color
It is rare that bar selection is actually made based on or using hard data and comparison.
Total Bar strength is primarily determined by 6 influences:
1. Hollow versus Solid (more on this later)
2. Bar thickness, the thicker the stronger
3. Bar length from bend to bend; shorter the better
4. Swing Arm length and angle; shorter & great angle are stronger
5. Bar material; high carbon steel required
6. Attachment methods; Geometry and rigidity
HOLLOW VERSUS SOLID
There is a SERIOUS amount of misunderstanding on this topic. To start, we need to understand a few engineering terms and define them as they relate to sway bars, in a simplistic manner:
SHEAR STRESS: Stress that is applied in a rotational method with respect to sway bars. The lower the number with a given load the stronger the sway bar will be. The formula for Shear Stress is:
Shear Stress (r)=torque (T) X Radius (R)/Polar Inertia (Ip)
POLAR MOMENT OF INERTIA: the ability of a sway bar to resist torque and while maintaining its original shape. The higher the number the better
The formula for Polar Inertia is:
Polar Inertia (Ip) = (Pi) X (OD^4 – ID^4)/32
OD equals outer diameter of the sway bar. ID equals inner diameter of the bar. To find the ID, subtract 2X wall thickness from the OD. If we are calculating a solid bar, then drop the ID^4 part of the calculation.
Before we actually calculate data, we need to understand wall thickness and what is typical. Wall thickness of sway bars is one of those mystic numbers. They are rarely talked about or even thought of, but the thickness is critical. Most hollow bars are in the .118inch thick tube range. This is due to pricing. The cost of the hollow tube material really starts to escalate as wall thickness escalates. Other tube size may max out at the .188inch range, which is a very aggressive bar, to a animal .250 range, which is usually not seen for street use.
At .188 inch of wall thickness, the bar will be 30% stronger than a .118 inch tube
At .250 inch of wall thickness, the bar will be 45% stronger than a .118inch tube
Here is a comparison between two 27mm bars, one being solid, and the other being hollow with a .188 inch (aggressive thickness!) tube:
To analyze the above data, given two 27mm bars the Ip of the solid bar is 52,194^4 and the 27mm hollow bar is 43,089^4
The solid bar is 21.11% stronger with an aggressive wall thickness .188Inches and 57.81% stronger than an normal .118 inch thick tube bar.
There are other “issues” hollow tube bars have that solid tube bars do not:
1. The stress is highly concentrated in the .118 inch thick tube, versus the radius of a solid bar. Thus the solid bar will have, in general, a greater life. It actually works out to be 111% higher stress than a solid bar material
2. All late model vehicle sway bars are subject to major bends for clearances
a. Hollow tube bends are not consistently predictable from 1 hollow bar to another, allowing greater variations in bar strength
b. This means actual bar strengths have a higher degree of variationfrom one hollow tube bar to another, as compared to a solid sway bar.
c. Bends also decrease diameter of the tube. At SEMA, I measured 2 different well-known brands. Here is the Data:
The arrow shows the reduction in bar diameter in a hollow tube bend from a major manufacturer of hollow tube bars. Even though the picture is small, you can visually see the diameter of the bars are smaller at the bends
To further understand, take 2 empty soda cans, and partially crush one of them. Then see which one twists easier!
3. Hollow bars may weigh approximately 40% less than solids, but answer these questions:
a. Will 6 pounds of sprung weight make a big difference??
b. Will 6 pounds of sprung weight located at the lowest part of the chassis have much effect on center of gravity??
c. How much weight did you add when you did your wheels and tire upgrades??
d. Unless you are building a all out race car, hollow bars offer little weight advantage to the big picture
SWAY BAR THICKNESS
Changing the thickness of our sway bars to improve performance is the largest influence on strength enhancement that we can do. For example, if you could double the thickness of a sway bar, you would increase the strength 1600%. Changing the thickness of a solid sway bar 1mm, will make a 19% to 22% improvement in strength. A hollow bar will have to be 2 to 4mm larger diameter to be equal in strength to a solid bar.
Here is a Strength Comparison Chart to demonstrate this:
There are limitations to diameters of bars due to clearance issues as a result of OE design and structure. But the bar diameter is the #1 change we have to make strength improvements.
BAR LENGTH
The strength of a bar is inversely proportional to the length of the bar. Bar length is measured from bend to bend at the frame rails, . Therefore, the shorter the bar the stronger it is. For example, if you reduce the bar length by .5 inches, the strength of the bar increases approximately 1.2%, based on a average bar lengths for Camaro, GTO, G8, Mustang, Challenger, etc..
However, bar length offers very little opportunities for changing due to the clearance issues and OE construction and layout restrictions.
SWING ARM LENGTH AND ANGLE
Sway bars are a horizontal torsion bar with swing arms applying leverage to the bar length ends. The shorter the length, the stronger the bar will be. For example, on average, changing the length of the swing arm .5 inches (13mm) , will change the strength of the bar approximately 2% to 5%.
The angle of the swing arm from the bar length also influences strength. For example, given a 16.5 inch long swing arm (C) when the length of the swing arms perpendicular to the bar length (A), will change 5% for every .5 inch change in perpendicular length. Using the picture below we are using the difference between C and A/ When the length (A) reduces compared to (C), strength will increase
Angles and lengths of the swing arms offer limited performance enhancement opportunities due to OE chassis design.
BAR MATERIAL
All sway bars, except for some serious special application race cars, are made of high carbon, hardened steel like 1080, 1095, 4130-4140, 4340, 5160 and chromoly. Turns out for actual strength, there is little difference between grades. But the quality and preparation of the metal are very important for long term durability and reliability. Hollow tube sway bar materials have to be a much higher quality than the materials used for solid bars to equal the durability of a solid bar. Remember, hollow bars experience much higher stresses than solid bars. But the quality of the metal is insignificant in determining strength.
ATTACHMENT METHODS
Nearly all sway bars are attached to the chassis through mounting bushings and end links. Firmer poly mount bushings add efficiency to sway bars as compared to soft rubber bushings. The improvement can be substantial! Double ball jointed end links are becoming much more popular than units using mounting bushings. In most cases, using double ball jointed end links help the sway bar improve its overall efficiency as compared to end links using OE soft rubber bushings. Also, traditionally the double ball jointed end links are more durable than OE rubber.
The location of the end-link attachment to the suspension in relationship to the knuckle is a serious influence to the efficiency of the bar. Case in point; the mounting positions for the rear sway bar end links on the 2010 Camaro are mounted 180mm from the inner control arm bushing (inner pivot). The outer control arm bushing (outer pivot) is 510mm from the inner control arm bushing (inner pivot). When the tire moves 25.4mm, the sway bar will only move 9mm. Therefore, the sway bar is only operating at 35% of its capability.
OE End link mountings and geometry offer only a small amount of sway bar improvements. Moving the end link .5 inches closer to the bar length will increase strength between 2 and 5%. However, when you are looking at adjustable sway bars front and rear with 3 adjustment positions each as the Pedders bars have, the overall changes can add up to quite a bit of bias adjustment.
Adjustable length end links are required for corner balancing. Corner balancing is the process of shifting weight front to rear, side to side and diagonally. This involves raising and lowering ride heights at the different corners, or shifting weight, or adding weight in some cases . It is entirely possible to have the left front corner sitting 10mm or more higher than the right front corner. Without adjustable end links, you will preload the sway bar, thus altering spring rates, which is not what you normally want.
Pedders includes adjustable High Effciency end links with all sway bar kits for the front and rear of the 2010 Camaro.
CAMARO SWAY BAR COMPARISONS
There are multiple choices that you have for selecting sway bars. It is important to understand the differences and benefits. It is surprising the differences between the manufacturing companies. The differences are so substantial, it appears that some may have a conservative figure of X% increase over stock OE and ship them, while not truly taking into account any specific handling concerns that a particular platform may have. Pedders evaluated over a dozen different bar combinations. Below we will do a review of the Pedders Camaro Systems, OE systems, and other aftermarket systems that have been collected data on. First, here is a breakdown of our 3 Pedders systems:
SOLUTION A: This entry level option offers a 27mm 3 way adjustable solid front sway bar, including 12mm HD adjustable end links. Solution A is designed to seriously attack front body roll, which is the number 1 improvement needed for the non-competitive , but sport enthusiast Camaro driver. When pushed past the 7/10 (Absolute Ability) level, understeer will be increased. Understeer is excessive in the Camaro, but body roll is really excessive and undesired, and the enthusiast requires its reduction. This package is 90% STRONGER than OE, and is designed for the budget oriented enthusiast that likes more control driving thru the twisties.
SOLUTION B: This will be our most popular sway bar kit and we feel it is the best sway bar package on the market. Solution B offers 27mm solid 3 way adjustable front and rear bars with 4 adjustable HD 12mm end links. The Solution B package is for aggressive street driving and non professional track use, and will significantly reduce body roll and understeer. Solution B is 90% front and 133% rear stronger than OE. It also increases the rear sway bar bias to the rear by 23%. This is specifically designed to improve understeer.
SOLUTION C: This package is designed for the SERIOUSLY aggressive driver who has SCCA or NASA training. Solution C offers a 27mm front and 32mm rear, 3 way adjustable solid sway bars with 3 adjustable HD end links. Solution C is 90% front and 360% rear stronger than OE, and will increase the rear sway bar bias to the rear by 142% to give the very aggressive, trained driver, the ability to induce a controlled understeer to oversteer modes. It is only recommended having Solution C installed on one of our major systems. If you have questions about this, you can call us.
ALL PEDDERS SWAY BAR KITS WILL REQUIRE ENLARGING THE END LINK MOUNTING HOLES TO ACCEPT THE LARGER HD BALL JOINTS
Before making some comparative review, lets discuss the bias ratio referred to above. If you look at the strengths of a front and rear bars as a relationship, you can determine a bias. For example, the OE Camaro bar has a bias of .815. Increasing the ratio number will move the Camaro closer to a potential oversteer concern if you go too high. But a higher ratio is seriously needed for the Camaro. It is the R&D that determines just how high to go and driving habits, setup of the Camaro, etc. The lower the number, the more understeer the Camaro will have. Now this ratio will be influenced by many factors from wheel base, to track, tires. the degree of suspension upgrades, the skills of the driver, and very important, the velocity and inertia of the car that is speed dependent. The faster you are going, the more influence you will have, These ratios may not apply the same to other vehicles. Also, we feel once over a ratio of 2.000, this could potentially present unsafe oversteer if not correctly set up.
Most of the Competitors' bars are hollow, and the tube thickness is an approximation. When looking at the prices keep in mind the Pedders bars include adjustable HD end links and the other manufacturers do not. The prices listed are estimates and subject to change at any time.
There is a lot of data here! Strength measured is a function of polar inertia. To make selections of bars requires looking at ratio, strength, and adjustability. For example,
1. Competitor A offers a VERY low ratio, considering they are replacing 2 sway bars, compared to Pedders Solution B ratio of 1.000 and a 90%/133% increase, compared to their 106% / 20% improvement. No end links are included with their kit
2. Competitor B is a good ratio, but offers much lower strength gains than the Pedders Solution B Package. No endlinks are included with their kit.
3. Competitor C offers a too high of a ratio, and too low of an increase in the front. This will reduce understeer , but will offer insufficient improvements in body roll. No endlinks are included with their kit
4. Competitor D offers a 2 sway bar kit with very good control in body role, but will increase understeer as compared to OE and Pedders Solution B. No endlinks are included with their kit. The Competitor D has a low ratio of .553 while the Pedders Solution B has an improved ratio of 1.00. The Pedders % improvement is 90%/133%, while the Competitor D offers a 111%/44%. Pedders again offers a better all around balance
5. Competitor E was found at SEMA but had their bars on their Camaro, but has not listed the Camaro yet on their website. They have the same size bars as Competitor B, but has the advantage of having a 2 way adjustable front bar compared to Competitor B. As in Competitor B, the balance is better than OE, but the front and rear strengths are seriously lower than Pedders Solution B at 53/87% increase over OE compared to Pedders 90/133% increase over OE
I hope this helps everyone see the value in comparative data and understand why Pedders Solution B is the best combination for street use compared to all others. There is a lot more data that can be shared, but may only potentially just make the processes more confusing. We are available for any questions. If the Bar manufacturers think they are included in the competitor selections and they want to give me their wall thicknesses, I will be glad to be 100% accurate, instead of the 90% to 95% accurate, and would be glad to change the numbers. But no one wants to give this data out. We asked every competitor except 1, and they either did not know the wall thickness, or do not want to give it out for proprietary reasons, which is understandable.
In conclusion, there are many factors that manufactures that determine overall bar strength, but the only significant one is bar diameter and wall thickness, due to fitment mandates established by OE chassis design. Comparative data is more important than actual final strengths, since shapes and length variations of sway bar components cannot be changed by much. I have the calculation process to determine actual strength of a bar, which can be used to make changes in dimensions and see how actual overall strength is affected. But it gets a little complicated to present on a forum and still keep it functionally accurate. Will work on this.
I tried to get the wall thickness of all the hollow bar manufacturers, to get to 100% accuracy. But again, that data is not given out. In most cases, I think I overstated the wall thickness in my calculations.
Thank you.
Mike (DMS)
Old 12-12-2012, 08:25 PM   #12
Ventmaster
Ventmaster's Avatar
Now I got it!
Old 12-13-2012, 03:29 PM   #13
LSRJohn
Drives: econobox
Caverman, I won't beat a dead horse, but I will thank you for choosing LSR Performance!
Let me know if there's anything I can help with, just shoot me a pm.
John
LSRJohn is offline   Reply With Quote
