Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 05-10-2014, 06:39 PM   #1
HP_atTheWheels
HP_atTheWheels's Avatar
Drives: 06 Vette
F/S Sub and amp wheel well boxes with sub and amp
DISCLAIMER!! The AMP in the pictures is no longer part of the package, it was sold, everything else is still available.
I have a set of drop in driver side sub box and passenger side amp stealth enclosures. I have had them for about 2 and a half years. Fit and sound are perfect.
The sub is a 10" Kicker Solar Baric L3 2ohm
Power Handling:
Peak: 800 watts
RMS: 400 watts
Impedance: Dual 2 ohm
Patented corner-ribbed, double-stitched Santoprene rubber surround
Stamped steel basket protects massive internal motion
Titanium deposit impregnated cone with rolled outer edge
Vented 360° back bracing
Rear foam gasket
Heat-dissipating, solid pole piece and high-temp coil wire for longer woofer life
Spring loaded terminals
Poly-cotton semi-progressive spider
Heat-dispersing, solid pole piece
Spiralead tinsel leads
High-temperature dual 2 ohms voice coils
Sensitivity: 85.3 dB
Looking to get $350 for all of it, will ship at buyers expense.
Please PM with questions!!
HP_atTheWheels is offline   Reply With Quote
Old 05-14-2014, 11:01 AM   #2
HP_atTheWheels
Drives: 06 Vette
Bump
Old 06-10-2014, 07:51 PM   #3
HP_atTheWheels
Drives: 06 Vette
bump
Old 06-10-2014, 09:01 PM   #4
F-16 Camaro
Drives: 2010 Camaro 2SS Black
Forgive my ignorance, but where do these go exactly?
Perhaps a pic installed?
F-16 Camaro is offline   Reply With Quote
Old 06-10-2014, 09:18 PM   #5
HP_atTheWheels
Drives: 06 Vette
I don't have any pictures of these installed, but the sub sits in the drivers side fender well in the trunk and the amp sits on the passenger side. here is a picture I found on google though. this one is and amp an sub combo, mine are individual.
Old 06-11-2014, 09:08 PM   #6
F-16 Camaro
Those look good. Out of my price range at the moment though
Old 06-12-2014, 09:36 AM   #7
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
so to verify, this wouldnt fit a 10 inch round sub? it's carved for square subs?
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 06-12-2014, 09:40 AM   #8
HP_atTheWheels
Drives: 06 Vette
That is correct, it will only fit square 10" sub
Old 06-12-2014, 09:45 AM   #9
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
with the passenger side insert, does the factory BA amp have to be re-located?
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 06-12-2014, 09:57 AM   #10
HP_atTheWheels
Drives: 06 Vette
Nope, no relocating anything, they both just drop into place
Old 09-15-2014, 11:06 AM   #11
HP_atTheWheels
Drives: 06 Vette
bump, updated
Old 09-15-2014, 12:30 PM   #12
cabbe
Drives: 2014 2ss 1le
Would you sell only the passenger side amp stealth enclosure?
cabbe is offline   Reply With Quote
