Old 02-23-2015, 06:35 PM   #1
huggerorangss
Drives: c6 corvette
Installed twin turbo and now reverse on m6 is locked out?
Hey guys,
Over the weekend finished my agp install. Never touched any of the trans stuff. For some reason, whenever I put the car into reverse, it is as if the reverse lockout solenoid is preventing me from putting it into reverse. Any ideas what might have happened or what might have caused it? It hasn't worked since initial startup, worked perfect before I installed the kit, wondering what I might've bumped? I did check the connectors on the trans all seem to be connected properly. I also cannot control the solenoid with my scanner. I have a hard time believing I have a bad solenoid being that the car only has 2000 miles.
Any help is great.
Thanks guys
huggerorangss is offline   Reply With Quote
Old 02-24-2015, 12:42 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Will it even go into reverse with the engine off? Any codes with your scanner?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-24-2015, 06:12 AM   #3
huggerorangss
Drives: c6 corvette
Will not go in with engine off. Had a reverse solenoid code, that stayed off when I cleared them, still has a skip shift code. Car has not been tuned yet.
Old 02-24-2015, 06:22 AM   #4
1KillerSS
1KillerSS's Avatar
Should be able to actuate the solenoid, that and the code kinda points to bad solenoid. Is it possible that you have a speed sensor unplugged? May be locking you out because it things its moving?
Build thread
Old 02-24-2015, 09:50 AM   #5
huggerorangss
Drives: c6 corvette
Thats kinda what I thought as well, but with the skip shift code being on too it made me wonder if that might be contributing to it. Thanks for the tips I'll take a look at my speed sensors, maybe I knocked it off on accident or something.
Old 02-24-2015, 09:52 AM   #6
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Call agp maybe they ran into this before?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-24-2015, 10:11 AM   #7
huggerorangss
Drives: c6 corvette
I was gonna give that a try also, I'm waiting for the car to get back from my tuner, seeing if he can figure it out first. Just seeing if anyone else had any insight or had this problem.
Old 02-24-2015, 10:43 AM   #8
Unreal
Drives: 2006 Z06
Only time I have seen this issue was on my own car. When I plugged the solenoid back in one of the pins inside the connector bent so it wasn't getting a connection. Popped connector off, bent pin back, and all good. Get under the car and check the solenoid and plug/connector and wiring to it. Not much to that system, so should be easy to figure out.
Nick
Corvette Z06 -1200ish rwhp
Old 02-24-2015, 02:32 PM   #9
huggerorangss
Drives: c6 corvette
I'll definitely give that a try.. Thanks!
Old 02-24-2015, 02:38 PM   #10
Jims73z
Jims73z's Avatar
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6
On my 2000 SS the solenoids for skip shift and the reverse lockout were swapped, same connectors.
Jims73z is offline   Reply With Quote
Old 02-24-2015, 04:23 PM   #11
huggerorangss
Drives: c6 corvette
Gotcha, ya that would definitely cause it.
Old 02-24-2015, 04:45 PM   #12
AGP Turbo
Drives: All things Turbocharged
TT's create wormholes. No need for reverse.
AGP Turbo is offline   Reply With Quote
Old 02-24-2015, 04:51 PM   #13
huggerorangss
Drives: c6 corvette
^kinda how I thought of it.
Old 02-24-2015, 04:51 PM   #14
1KillerSS
1KillerSS's Avatar
Build thread
