03-29-2015, 06:38 PM | #1 |
Drives: 2013 1LE/SS Join Date: Mar 2012
How do I remove buffing compound
Dealer buffed car before I bought it, and went over the factory splitter with the buffer I guess. They tried to remove it and said they couldn't, if they tried anymore it would fade the splitter. So I'm going to try myself, any suggestions on what to use to get the compound off? I'm tired of looking at it.
Current mods: Stainless Power Long Tube Headers,Cat Delete,CAI Cold Air Intake,Vitesse throttle controller, Muffler/Resonator Delete w/dual tips. ADM Performance Tuned,BMR 1.25 lowering springs,R1 Concept Slotted/Dimpled Rotors.
03-29-2015, 06:44 PM | #2 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
All purpose cleaner with a toothbrush.
Detailing is an involuntary obsession.
03-29-2015, 07:29 PM | #3 |
best one for me so far white pencil eraser
03-29-2015, 07:43 PM | #4 | |
I like teeth.
Drives: #198 Join Date: Oct 2009
wax/buffing compound, same way to remove
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
03-29-2015, 08:07 PM | #5 |
Appreciate the tips, I'll try to remove tomorrow. I was about to flip out, because they also buffed the front bumper with the hood down, which is no good when you have 1le black wrapped vinyl hood! Luckily I was able to remove the compound from edge of hood, and didn't have any burn marks. I should have just said no detail, give me the car.
03-29-2015, 08:17 PM | #6 | |
I know it sounds crazy but the oils in the peanut butter or vegetable/peanut oil will remove it. Just make sure it's cool to the touch (the affected area), and if you have painters or masking tape, tape off the painted area above it. |
04-01-2015, 08:58 PM | #7 |
Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
I use those erasers at work..am an engineer..
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
04-02-2015, 10:37 AM | #8 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
You must mean the calculate, draw, calculate kind of engineer, not the Toot-Toot, all aboard! kind.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
