04-06-2015, 12:23 PM | #1 |
Drives: 2010 2SS Join Date: Nov 2013
102mm Throttle body on TVS2300
Ok, lets beat this to death one more time
I am tempting to max out my tvs2300 setup, one of the last things left is open it up to a 102mm and throttle body. I found an older post by Ray@RDS saying they were doing some testing and thought they might be onto the cause of the throttle plate closing/limp mode. Anyone have anything on this? I hate to spend the 800 dollars on the machine work and throttle body to just have issues. However it looks like this could gain about 20-40 rwhp from what I have read in most cases. |
04-06-2015, 03:38 PM | #2 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Contact JessRayo on here I believe he finally worked out his problem.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
04-06-2015, 05:11 PM | #3 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
If Ray at RDS can offer a guarantee that his "calibration" works go for it.
Larger throttle bodies in high HP applications have proven to make decent gains. There is no proven cure for the reduced engine power issue that I know of yet. |
04-06-2015, 06:02 PM | #4 |
That's what I was figuring, then the guy that tunes the car said just leave the stock one on it for now.
04-06-2015, 07:13 PM | #5 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Been running a 102 for years no issues. The problem was with NW TB's. MY TPIS solved this in 09....
Well maybe not 09 but you get the point, lol
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
04-06-2015, 07:45 PM | #6 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
04-06-2015, 08:25 PM | #7 |
I didn't see the tpis even being offered right now.
H-E I will give you a call tomorrow. |
04-06-2015, 09:28 PM | #8 |
04-06-2015, 09:34 PM | #9 |
When I was at the Texas mile last year it was still a common problem on big HP cars. I think there are a few rare units out there that seem to have a little extra tq needed to stay open. I don't know for a fact but I think speed density tunes have better luck at staying open as well.
04-07-2015, 09:09 AM | #10 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
2 years and no problems with my NW102 at over 800rwhp.
01-17-2018, 03:14 PM | #11 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
01-18-2018, 05:41 AM | #12 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
NW told me directly only positive displacement super chargers create the problem with his setups.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
01-18-2018, 06:53 AM | #13 |
I have a nw and it wont stay open past 4600rpm and 14psi
Sent from my SM-N950U using Tapatalk |
01-18-2018, 08:13 AM | #14 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Running NW 102 with proper adapter 16 lbs.. no issue.
