Old 08-12-2015, 10:43 PM   #1
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Dynatech 2" Headers, 3" Outlet SuperCats, Modified Billy Boat Fusion Exhaust
Installed the following and got it tuned:
Ceramic Coated 2" Primary Dynatech Long Tube Headers
3" Outlet Dynatech SuperCats (Welded in an extra O2 bung for Wideband)
Billy Boat 3" Fusion Dual Mode Exhaust (Modified for 3" Tubing Entire Length, removed 2.5" section and welded 3" extension)
Drove the car a little and checked for leaks and rattles.
All the parts fit great.
Had to remove the rubber boot on the steering joint, cut off the extra threads on the passenger firewall stud and trim the belly pan. (No Big Deal At All)
The car starts awesome and has an aggressive tone and then settles down into a nice growl.
With the valves open it has lots of character and sounds amazing!
Loud when you get on it but not crazy when just cruising.
With the valves closed you could sneak up on a cop eating donuts...
No drone, period.
So far I am really happy with the setup!
Note: You do loose about 2.5" of ground clearance at the Collector/Cat location. No big deal if you know this upfront but I learned it the hard way.
Lost 3 lbs of boost and the car feels a lot quicker!
Also had to swap the DR's out (the bald ones were my second set to look like this and they held pretty strong until they showed the cords.
2013 ZL1 #7860 is offline   Reply With Quote
Old 08-14-2015, 01:40 AM   #2
kenny powers
Drives: 2012 Black ZL1
very cool
kenny powers is offline   Reply With Quote
Old 08-14-2015, 11:00 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
No drone, period.
Glad you like them Thank you for your business.
Let us know how much you pick up at the track.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-22-2015, 08:09 PM   #4
2013 ZL1 #7860
Ted.
Thank you as always.
Car ran great but I wasn't driving it.
It ran 11.63 at 120 in 9,000 DA.
Then it ran another 11.63 right after that!
Can't wait to see what it can do in a more normal 7,000 DA day.
Old 08-23-2015, 03:07 AM   #5
himmy33
Go Cougs!
himmy33's Avatar
Drives: 2012 Ashen Gray ZL1
I guess I'm stupid concerning this but how can one pick up performance when loosing 3 lbs of boost? Seems like a considerable amount for these cars. Does your car have other modifications? Your help with this is greatly appreciated.
himmy33 is offline   Reply With Quote
Old 08-23-2015, 09:02 AM   #6
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
Boost is just a measure of restriction. Higher flow through the new exhaust lowers restriction, therefore lowering boost pressure. Since efficiency is up and restriction down, power will be more then it was.
Azzkker is offline   Reply With Quote
Old 08-23-2015, 09:51 AM   #7
2013 ZL1 #7860
Boost is not a measure of HP but many people jump on the "boost" bandwagon because ricers love saying "I'm pushing xx lbs of boost".
I really only look at the boost numbers when I make a change to the car or if something is wrong.
Less restriction means more air flow and less resistance.
Old 08-28-2015, 03:56 AM   #8
himmy33
Go Cougs!
himmy33's Avatar
Thank you for the info guys. This makes much more sense to me.
