Old 09-07-2015, 01:12 PM   #1
Faster12
Faster12's Avatar
Drives: 2012 Black ZL1 #1158
Procharged ZL1?
So I was looking at the new C7 Z06 and I ran across an article about how, at stock boost levels, stock timing, and pump gas...the procharger F2 made 115 more HP than the the stock blower. The setup for the Z06 looks phenomenal. What I can't seem to find is any information on a procharger setup for a ZL1. For you real car guys...what do you think the benefit would be..is it a viable option? Opinions please.
Faster12 is offline   Reply With Quote
Old 09-07-2015, 05:35 PM   #2
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
havent seen it done yet. Most either port the blower or go with the Heartbeat, if not twin turbo but no one has ever went procharger route
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 09-07-2015, 06:54 PM   #3
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Not seeing that kind of a gain at the same boost, timing, fuel, etc. the only two ways you would gain "peak" hp would be for the parasitic loss to be that much less or the intake air temps to be near freezing, and that still wouldn't do it.
I think twin turbos are the way to go, (I am biased) as they free up hp from the crank and have way more cfm capability than the heartbeat.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 09-07-2015, 09:55 PM   #4
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
A F1-a Procharger would produce the same power, anything bigger than that might cause fitment issues, supporting mods.
I'd be much more interested in seeing a 2.9whipple, 3.4kenne bell and big twin screw Swaps... The heartbeat creates good power and better cooling than stock SC, but I'd really enjoy seeing what a 3.4 with supporting mods would throw down. Might not fit under the stock hood but a copo cowl hood with ZL1 CF insert would look Radical
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 09-11-2015, 08:44 AM   #5
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Ayousef had a 4.0 whipple on a zl1
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 09-12-2015, 03:49 PM   #6
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
I seem to remember that the firewall was modified to fit the big wipple as he was running the sand rail version I believe.
Azzkker is offline   Reply With Quote
Old 09-12-2015, 04:24 PM   #7
brokencilence
brokencilence's Avatar
Drives: '14 1LE, Z28.R
I remember all the facebook updates when New Era Performance built that car. Lots of firewall and cowl modifications due to it being a rear inlet rather than front. Also the stock hood did not fit anymore.
Far beyond stock....
brokencilence is offline   Reply With Quote
