05-08-2013, 03:26 PM | #1 |
Drives: Cyber Gray 2011 2LT Camaro Join Date: Aug 2010
Track Tires for Stock 19s
So I got new wheels and want to use my stock 19s for the track.
1. What tires would you suggest for the track? 2. What size would fit the stock 19s? 3. Nittos seem to be recommended a lot but aren't sold on tirerack, where else would you recommend buying them from? Thanks |
05-09-2013, 02:55 PM | #2 |
Anyone?
05-09-2013, 06:24 PM | #3 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
What kind of track are we talking? Autocross, drag, or road course/ track days?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
05-10-2013, 01:59 PM | #4 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
There is just not much available for what will fit the 19 inch factory wheel. If you go to wider aftermarket wheels you can run a 285/40R19 Michelin Pilot Super Sport.
05-13-2013, 10:40 AM | #5 |
05-13-2013, 10:44 AM | #6 |
ITCRNRS
What is the stock tire size on the 19"s?
05-13-2013, 11:03 AM | #7 |
ITCRNRS
Looking on tire rack you can find a few cocky tires if you sway to a 245/45R19 or a 255/45R19, but nothing in stock size at all. Both of these sizes will be a little bit shorter but that will help the v6 get off the line and back up to speed quicker out of the turns
http://www.tirerack.com/tires/TireSe...45&diameter=19 http://www.tirerack.com/tires/TireSe...tpackage=false
