#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
BeckyD @ James Martin Chevy
Old 02-20-2016, 10:03 AM   #1
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
DJ-Silver 2SS's Avatar
Drives: 13 IOM ZL1 M6 & 10 SIM 2SS M6
Send a message via Yahoo to DJ-Silver 2SS
ESE pushing through added Sub in a 2SS
Does anyone know how to shut off the ESE (Engine Sound Enhancement) on the 2SS models? I have put a sub in one, but it is piping the exhaust rumble through the sub...... 😡 I have seen a company or two reference it, but how to you shut it off or bypass it in the sub? Any thoughts?
2013 IOM ZL1 #002415 Born 09/13/12
2010 SIM 2SS/RS #005549 Born 05/02/09
DJ-Silver 2SS is offline   Reply With Quote
Old 02-20-2016, 10:27 AM   #2
brutusvk
Drives: future 2016 SS
It does not have electronic sound pumped through the stereo o. The 2ss. There is mechanical sound through the intake. The 4 cyl turbo cars were supposed to have a sound enhancement. I added subs with no issue. Sounds like you have some other issue going on. I would guess a ground problem.
brutusvk is offline   Reply With Quote
Old 02-20-2016, 10:35 AM   #3
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
+ 1!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 02-20-2016, 01:16 PM   #4
Driski
Drives: 2016 Camaro Convertible 2SS
What is the best way to loose the sound pumped through the intake? I don't think I will need it. Please advise.
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 02-20-2016, 01:55 PM   #5
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I know on other cars that have had this you could simply remove the tube and plug it on the air intake.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 02-20-2016, 04:14 PM   #6
brutusvk
Exactly. Just disconnect and plug.
Old 02-20-2016, 05:50 PM   #7
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Got any pictures of what this annoying sounding "feature" plug looks like. Looks like I have half a dozen things plugged into my intake.
cellsafemode is offline   Reply With Quote
Old 02-20-2016, 07:10 PM   #8
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
I wish to agree with all of you, but engine sound is being pushed through the speakers. Using a rca converter attached to the rear speakers, it pushes a audible engine tone through the bass side. It's not a constant sound or a faulty ground sound, like with interference or high pitched whine. It is not present when the doors or trunk are opened, it is only present when the car is prepared to drive. I found that ******** has run into the same issue.
Old 02-20-2016, 07:10 PM   #9
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
Where did you attach your leads for RCAs?
Old 02-20-2016, 07:19 PM   #10
SuperSound
SuperSound's Avatar
Sounds more like a bad ground or EMI. There is no engine sound pumped in to the speakers. Plus fake engine sounds in cars with it don't use only the sub. They use the all the speakers.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 02-20-2016, 07:24 PM   #11
brutusvk
There is no electronic engine noise on v8s. 4 cyl only.
As for connecting rcas I use a Fosgate 3sixty.3
Old 02-20-2016, 07:27 PM   #12
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
I am tracking that, and the ground was checked. What is confusing is it only does it when both doors are shut as well as the trunk. It is actually a low tone loping sound and increases pitch with accelerator movement, which has led me to asking about the ESE. I thought it was a bad connection, but everything else is solid. I even took a set of RCAs and connecting them to my other car..... And no extra sound. It is mind boggling at the moment.
Old 02-20-2016, 07:28 PM   #13
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
To where?
Old 02-20-2016, 07:38 PM   #14
SuperSound
SuperSound's Avatar
But that doesn't eliminate your signal wires in the car, just the sub and amp you are using. What did you splice into for RCAs? We are kind of in new territory here. Not sure anyone has sub setup in the 2SS yet. If they do, no one has mentioned issues.
