04-05-2019, 10:47 AM | #1 |
Next Mod?
Hey guys, looking at getting my next mod and I can't decide between the Boostolator or a catless downpipe.
Which one will give me more hp? I also don't care about emissions because I live in Louisiana. Current mods are as follows: Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back. Appreciate any recommendations.
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
04-05-2019, 10:52 AM | #2 |
Downpipe doesn't require a tune boost does if I remember correctly
04-05-2019, 10:57 AM | #3 |
I'm getting a check engine light either way. Catless or Boostolator.
04-05-2019, 11:51 AM | #4 |
I'm not an expert on the boost o later...but I recall seeing something along the lines of you need to tune the car to accommodate the new piece on the turbo it's not just a CEL you'll be getting
04-05-2019, 12:06 PM | #5 |
Drives: 2016 camaro 2.0t gray Join Date: Apr 2017
I'd get the Down pipe first. This mod nets the most power gained. Are you going to be tuning soon?
04-05-2019, 12:11 PM | #6 |
Drives: 2018 2SS Join Date: Oct 2017
i would definitely do a DP first.
04-05-2019, 01:30 PM | #7 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
The boost a lator does not need a "tune". Just a software programmer to disable code P2261. Also, the boost a lator as its so affectionately called, or what its actually called, a recirculation valve, yields way more noticeable gains than a downpipe.
*Code P2261 doesn't hurt the car in any way when the CEL is triggered from it. It's just annoying you have a CEL on your dashboard.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
04-05-2019, 02:31 PM | #8 |
Drives: 2013 ATS M6, 95 Z28 Conv M6 turbo Join Date: Apr 2017
04-05-2019, 02:50 PM | #9 |
Not until at least this upcoming fall.
04-05-2019, 02:53 PM | #10 |
I don't have E85, "major mods", or even a tune.
04-06-2019, 12:47 AM | #11 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
04-06-2019, 01:28 PM | #12 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
The missing piece of info here is IF YOU ALREADY HAVE A TUNE, adding the performance recalculation valve can only POTENTIALLY result in undesired overboosting if you already have a tune. It's not an issue if you are on the stock tune. If you ALREADY HAVE a tune and add the performance recirculation valve, it is recommended to do some logging to see where your boost is at. Due to the many different ways to tune this engine, and everyone seems to do it different, your boost may be higher than desired after adding the valve with a tune. For instance, one customer noticed a 4 psi increase above his desired boost level. He adjusted the tune to compensate, and done deal. It will vary from tune to tune based on tuner. It will not overboost dangerously on a stock tune. You may see up around a 1psi increase, but that is fine. The valve can be run on a stock tune, and the only reason we recommended a tune, or called it the "tune version" is because it will throw a check engine light due to seeing more boost when the computer isn't expecting it. On a stock tune you can either live with the check engine light on all the time, or clear it when it pops up. The frequency of how often the cel comes on is determined by how you drive the car. I personally get the cel about once every 3-6 weeks of daily driving, 50miles round trip per day. |
04-06-2019, 10:22 PM | #13 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
IDK.....I think I did pretty well with my only bolt on, the BOL.
04-06-2019, 11:08 PM | #14 |
The aftermarket JacFab/BNR Recirculation Valve should be everyone's 1st mod.
