Old 07-11-2012, 04:13 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING LS3 NEW SUPERSTREET BRAWLER PACKAGE
Utilizing the Whipple Supercharger system and combining Some JRE components and tuning the results are Pretty impressive.
Our Customer Shawn from Massachusetts purchased and installed the JRE Do it yourself Street Brawler and JRE Rough Idle Blower Cam package and supporting fuel components.
I sent him a base tune to drive it here and I just finished tuning it on the dyno.
LS3/M6
JRE Rough Idle blower cam package
Whipple supercharger 3.75 pulley
ZR-1 Map
ZR-1 Plugs
LPE Dual fuel pump system
Injector Dynamics ID-850s
CAI with JRE Scoop
Rotofab washer bottle relocation
Dynatech LT Headers w OR pipes
JRE Custom Tuning
690 RWHP 588 RWTQ on 93 octane pump gas.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-11-2012, 04:39 PM   #2
GraysonPeace
"Go on the last yellow.."
GraysonPeace's Avatar
Drives: 2010 2SS/RS L99 CGM
Nice!! How much boost, and what gauges do you guys use?
Blown and built by Ty Sochacki, tuned by Jeremy Formato. Member of the 11 second club.
GraysonPeace is offline   Reply With Quote
Old 07-11-2012, 05:26 PM   #3
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Nice. I can't wait i just ordered a Whipple from Ted and already have the rough idle blower cam
94guy is offline   Reply With Quote
Old 07-11-2012, 05:37 PM   #4
Higgs Boson
Perpetual Order
Drives: indeed
anyone remember when it was hard to get 690 rwhp? lol. cool.
Higgs Boson is offline   Reply With Quote
Old 07-11-2012, 05:52 PM   #5
iUAE
3bood
iUAE's Avatar
Drives: Camaro 2010
Very nice, haw much boost?
iUAE is offline   Reply With Quote
Old 07-11-2012, 06:01 PM   #6
old motorhead
Drives: Maggie blown LS3 vette
The green line that has "Man P" stamped is boost....I'm guessing. 11 psi.
old motorhead is offline   Reply With Quote
Old 07-11-2012, 06:46 PM   #7
EncoreCamaros
EncoreCamaros's Avatar
Drives: 2010 Victory Red Camaro SS/RS LS3
How safe is this amount of wheel hp and amount of boost on a stock bottom end?
ARH 1 7/8 headers catless 3'' long system, Whipple sc 4.00 pulley 9 lbs boost, msd boost-a-pump, CAI intake, Pfadt coilovers, toe links, trailing arms, solid cradle bushings, sway bars, Forgestar CF5 19x9.5/19x11, M/T et street II radials
EncoreCamaros is offline   Reply With Quote
Old 07-11-2012, 07:11 PM   #8
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Depends on a bunch of variables such as how hard you drive it, the tune (which in this case is no issue), and fueling which also seems more than adequate, and of course luck. Safe probably is not the best word, reliable is probably more adequate....have a back up just in case Things can and do happen.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-11-2012, 07:16 PM   #9
awesome numbers, another Jannetty monster 5th Gen
Old 07-11-2012, 07:17 PM   #10
EncoreCamaros
Id give up a few pounds of boost and hp to a larger 3.75 pulley, to be a little bit more on the safe side. Those are awesome numbers thou! Ted tuned my car and it runs better then perfect.
Old 07-11-2012, 07:24 PM   #11
scottywheels
Drives: 2010 A6 SS/RS
Nice work Ted......cant wait for mine to be done...
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built
scottywheels is offline   Reply With Quote
Old 07-11-2012, 07:40 PM   #12
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
HOLY MONKEY.WOOT
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 07-11-2012, 08:27 PM   #13
JANNETTYRACING
Yep 9 psi for the majority, but climbs, toward redline, and just Kissed 10.9 psi.
The Power is still climbing at 7200 so I don't know how much more it would make if I let it.
It has a 3.750 pulley Edit .
Old 07-11-2012, 08:28 PM   #14
Gagootz78
Gagootz78's Avatar
Drives: 2010 2SS Camaro
Sweet Ted! You are the man! I've got the same supporting mods and now saving up for the Whipple. I can't wait!
Gagootz78 is offline   Reply With Quote
