View Poll Results: Cam or Gears?
Cam (Night Fury or the likes) 45 45.00%
3.91 Gears (LS3 M6 Car) 55 55.00%
Voters: 100. You may not vote on this poll
Old 08-16-2012, 04:08 PM   #1
2012REDSS
Drives: 2012 Camaro SS
Cam or Gears
Ok I'm at the point where I have bolted everything with the exception of a ported intake mani to my engine but I want more. I'm on a roughly $2200 to $2300 budget which will cover the gears or the cam. I drag my car usually a couple weekends a month however its also my DD and I average around 17,000 miles a year. The cam I want is something like the night fury cam and the gears are the 3.91s. The only suspension mods I have are BMR toe links and trailing arms and a ZL1 rear sway. Opinions?
2012REDSS is offline   Reply With Quote
Old 08-16-2012, 04:12 PM   #2
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
Cams are awsome but, I would do the 3.91 gears 1st. I did the G6X3 cam back in 2010 and just did the gears last month. The gears made a world of difference on the car.
Drew10 is offline   Reply With Quote
Old 08-16-2012, 04:14 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
cam for sure. that rumble at idle is like none other. gears dont turn heads
Old 08-16-2012, 04:15 PM   #4
Steve@SNL/Monster Clutch
Drives: 2014 SS
True that^
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 08-16-2012, 04:17 PM   #5
Drew10
Drew10's Avatar
This is true.
Old 08-16-2012, 04:41 PM   #6
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Gears all the way. Preferably both. If I could only choose one. Gears!
Obzen is offline   Reply With Quote
Old 08-16-2012, 04:46 PM   #7
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
They do at the track when you start to pull away from the competition
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 08-16-2012, 05:06 PM   #8
Higgs Boson
Perpetual Order
Drives: indeed
gears because gears don't turn heads.
Higgs Boson is offline   Reply With Quote
Old 08-16-2012, 05:10 PM   #9
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
both
1. Gears
2. Cam
3. ...
mike.nite is offline   Reply With Quote
Old 08-16-2012, 05:12 PM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
I don't have a cam but I will say the gears made a pretty significant difference.
I'm waiting on a cam for a while. To me, once you go into the motor it's like no turning back. Having simple bolt ons and gears is usually no big deal to people if you were to ever sell your car. Cam on the other hand can make people think twice. At least I would.
Now, you might wait just a little longer to do either. It sounds like GM will be releasing the 3.91 gears from the 1LE soon. From what I've heard they are about 1/2 the price as LPE is selling them now. Someone on the 1LE forum was getting them for under $400 and then $400 or so for the install. You're looking at $800 - $850 vs going and getting them right now the LPE gears cost that alone.
Maybe go with the LPE gears, save up a little money, and do both.
Build Journal
Old 08-16-2012, 05:16 PM   #11
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
+1, I never considered a big cam but I am considering a small cam. Good point about the big cam come resale time.
audiomikej is offline   Reply With Quote
Old 08-16-2012, 05:18 PM   #12
audiomikej
audiomikej's Avatar
OP, Also since you drag so much consider saving to replace the axles since this is your DD. Drag racing with 3.91 will be much harder on the stock axles.
Old 08-16-2012, 05:26 PM   #13
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
I have both.. I'd say gears. I loved the s*** out of my gears when I got them done. It was after the motor build too! :-)
The 2010 Sin is offline   Reply With Quote
Old 08-16-2012, 06:58 PM   #14
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
depends on the application...
gears would be great on the strip and they have a great butt dyno.... but damn the responses I have had at car shows and at red lights... yes red lights, where people constantly asking what size cam I have and that it sounds incredible.
so for me... cam because you get performance and sound, but it is a very, VERY close call.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
