Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 09-23-2019, 04:24 PM   #1
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
SOLD - AeroForce Interceptor Gauge w/Pod
For Sale - AeroForce Interceptor Gauge with Summit Racing "Carbon Fiber" pod & OBDII Connector.
Asking $125.00 + $15.00 Priority Mail Shipping
-- These now list for $249. on their website - Pod goes for ~$16.
PayPal-only - will send Tracking # as soon as payment is posted - PM with interest.
Traded in my 2010 RS A6 Camaro so no longer needed - perfect working condition. I had the pod on the left side of my dash with cable carefully snaked into the side fuse panel so the OBDII could plug in. This way I was able to remove when needed for an overnight at hotel to avoid someone stealing it.
Silver Face, fully customizable, with shift lights & cycles through 4 parameters, including:
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog input
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
Old 09-23-2019, 07:21 PM   #2
Badmag71
Badmag71's Avatar
Drives: 2010 camaro ss
pm sent
Badmag71 is offline   Reply With Quote
Old 09-23-2019, 08:11 PM   #3
tjd24
tjd24's Avatar
PM sent - SOLD
Originally Posted by Badmag71 View Post
pm sent
Old 09-23-2019, 09:43 PM   #4
Badmag71
Badmag71's Avatar
Thanks!
