Old 07-29-2014, 11:25 PM   #1
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
Leaking Transmission
Has anyone experienced a transmission leak in their 1LE?
Since day one there has been a leak somewhere. It has been back to the dealer three times now. The leak appears to be coming from the top somewhere. Last time in the dlr. They pulled the trans and resealed up by the shifter. Alas, I backed out of the garage the other day to find another puddle.
There's not a lot of places the fluid can come from down there. I am wide open for ideas before it goes in again. I'm at about 22000miles.
1LeSS is offline   Reply With Quote
Old 07-29-2014, 11:26 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Bummer, no leaks.
cornerspeed92 is offline   Reply With Quote
Old 07-30-2014, 08:59 AM   #3
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Just short of 18K miles....no leaks.
gajagfan is offline   Reply With Quote
Old 07-30-2014, 09:41 AM   #4
Texzen
Texzen's Avatar
Drives: 2013 SW 2SS/RS/1LE
27.5k miles, no leaks. I'll poke around under my car tonight and see if I can suss out where a leak like that might come from. :|
Texzen is offline   Reply With Quote
Old 07-30-2014, 11:38 AM   #5
1LeSS
1LeSS's Avatar
Thanks buddy ... I'm looking for any input.
Old 07-30-2014, 02:57 PM   #6
That_Guy
That_Guy's Avatar
Drives: n/a
Probably the vent tube.
That_Guy is offline   Reply With Quote
Old 07-30-2014, 07:22 PM   #7
1LeSS
1LeSS's Avatar
Update, took the car to the dlr today to go through the process once again. The car is on the host, 3-4 guys underneath it with flashlights. They say, "yup, its leaking from up there" (this is just like last time and in my opinion a waste of my time). So I'm told to go and make an appt. I asked them what they are going to do as this is the fourth time its been in for the same problem. They didn't know. So I said, to me what was obvious, "since the appt. will be after the long weekend why don't you guys put some dye in the tranny and then you might be able to see where its coming from". Wow, you'd think they never heard of dye before. Ok, so I'm venting a little here. They put some dye in and tell me to drive the car lots.
One guy did say that maybe the casing is porous. Guess that's possible because there are certainly not many places on a manual tranny that fluid can come from. Guess we have to wait and see.
Old 07-30-2014, 07:24 PM   #8
1LeSS
1LeSS's Avatar
possibly, I hope the dye shows us something. I'll write a list of things for them to check since the ideas didn't seem to be flowing that well today.
Anyone know where I might get a schematic of the tranny??
Old 05-27-2015, 07:10 PM   #9
1LeSS
1LeSS's Avatar
Update, after agreeing o a new case, they pulled the trans out again.
I was at the store so they called me into the shop.
I could see it as I was walking up to three mechanics standing around.
I said, REALLY???!! From a distance you could see the bolt for the shift détente was not tight and oil leaking out of it.
So after all the times f taking the Tran in and out, all the hassle and arguments. All that was needed was a tech that bothered to look for the obvious.
We now close this case. Morons
BC Racing coil-overs, 32ml rear sway bar, Solid cradle bushing kit, Steel jacket radius rod bushes, JPSS caster bolt, Bo White TB, Granitelli HP coils, Apex Catchcan, Vortech V7 Ysi Supercharger, LSX B-15 engine, custom spec cam, and other stuff.
