#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
AWE Tuning
Old 01-02-2018, 08:30 PM   #1
PRAY
PRAY's Avatar
Drives: 2016 2SS
Track tested the RF vs. cut stock box and Green filter.
We were able to test the RF w/ dry filter vs. the Stock CAI with the bottom of the box cut out and running a Green filter. We got the car dialed in in the "stock" configuration first. I think the pass represented was done in -300 to -400 DA. The two RF tests were done at the end of the day in +100 DA. We ran out of time to do multiple runs in each configuration. You can tell that even with higher DA and a slower 60ft the RF was just plain faster than a modified stock box with the Green filter. The last test we tried was to run the stock CAI's inlet tube on the RF box. In my mind the taper of the stock tube and the two 60* bends could be a benefit over the RF's non tapered tube with a 120* bend. We did not tuning for the RF tests. We just slapped it on and ran. The results of that test were inconclusive in my mind. Here is how it laid out.
Name:  RF track test.jpeg
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
PRAY is offline   Reply With Quote
Old 01-02-2018, 09:36 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
Thanks for the info! One of these days I'll get the Rotofab intake!
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 01-03-2018, 04:43 AM   #3
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Interesting. Do you expect to do more testing in these configs, specifically RF with stock tube??
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
driven2exceSS is offline   Reply With Quote
Old 01-03-2018, 04:54 AM   #4
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by driven2exceSS View Post
Interesting. Do you expect to do move testing in these configs, specifically RF with stock tube??
I may see what the stock tube does on my car at some point. But testing against stock or any variation of stock is pointless to me. I have been saying for a year that the RF is a producer. I have seen it many times on the dyno and now verified on the track. There is no question in my mind at all that the RF is the best CAI out there.
Old 01-03-2018, 12:53 PM   #5
oldman
Drives: SS 6 speed of course
convincing, real world, many thanks!
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
Old 01-03-2018, 09:01 PM   #6
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Is anyone else concerned about running a rotofab dry filter and its ability to capture dust compared to the stock filter? I would like to do an oil analysis and look for silica and evidence of dust.
Also what about the ZL1 air intake? I looked at gmpartsdirect and the ZL1 air intake appears to have all the same part numbers as the LT1 SS intake, is this true, are they the same intake?
cmitchell17 is offline   Reply With Quote
Old 01-03-2018, 09:04 PM   #7
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Attachment 914023
Pretty well dead even, your Roto fab out of the hole was yours best time. So really Roto Fab was last.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-04-2018, 04:34 AM   #8
PRAY
PRAY's Avatar
Drives: 2016 2SS
What? I am going to guess that I don't get what you are saying. The stock, cut up box with the Green filter had the best 60ft and was done in basically -500 DA better than the RF tests and was still half a tenth and 1 mph behind. What am I missing from what you wrote?
People claim that the cut box and Green filter are better than the RF. Clearly that isn't the case at the track. 1 mph is significant, especially over a modified box with a filter. The gap would have been much larger had this been a stock air box.
I am not sure why the 60ft is off by .002 except for the climb in the DA but I didn't tune or drive this car. I adjusted some shift points but that was about it. All of us saw a .001-.002 rise in 60ft as the day went along so I guess it was consistent.
Old 01-04-2018, 04:42 AM   #9
PRAY
PRAY's Avatar
Drives: 2016 2SS
The Dry filter does not catch the same amount of dust as the stock filter. Nor will it catch as much as the oiled filter.
The ZL1 air tube is different than stock. It did show the same number as the LT1 when I was trying to get one for my LT4 conversion. I had to pull up the diagram and show the parts person which one I wanted. You had to get it by car VIN back then.
Old 01-04-2018, 02:44 PM   #10
driven2exceSS
Please excuse my inability to follow along... when you speak of the stock tube, are we talking about the SS stock tube or the ZL1 stock tube on the RF in your testing? I have your ported stock IM, and a dry RF in the garage, and was thinking when I finally get to do the install it would be worth following your testing results if it is indeed the stock A8 2SS tube getting the gains over the RF tube with no said fuel conversion. I am just starting to look into the E85 idea, and in my limited research it seems EFI Tuning's kit is the preferred.
Old 01-04-2018, 02:58 PM   #11
PRAY
PRAY's Avatar
Drives: 2016 2SS
Too easy buddy. Testing was done on a 2SS. Not a ZL1. The tube is the connecting piece from the CAI to the TB. You can use either tube on the RF. So from after the hard piece with the MAF in it. I have no idea where the ZL1 piece came from. It won't fit the stock or RF to the TB so it is out regardless. I would have to do more testing between the tubes. But the concept is sound and interesting.
Old 01-04-2018, 03:17 PM   #12
driven2exceSS
Lol the parts identification are elementary. I guess cmitchell17 threw me off with his post. Thank you again Sir for all you do!
Old 01-04-2018, 05:11 PM   #13
JFM-jr
JFM-jr's Avatar
Drives: 2016 Camaro 2SS
Interesting results thanks for taking the time to do this and reporting your results for everyone here read.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 01-04-2018, 05:57 PM   #14
PRAY
PRAY's Avatar
Drives: 2016 2SS
NP
