Old 02-11-2014, 04:22 PM   #1
cmc9795
Drives: 2011 1LT/RS
Plastidip rear blackout?
Can i see some pics of the rear blackouts made with plastidip? And how did you cover the rear emblem when you did it? Did you cover the emblem alone with tape?
American Racing 20" Torque Thrust rims, Stripe kits, Vararam intake, and MRT V2.
cmc9795 is offline   Reply With Quote
Old 02-11-2014, 04:37 PM   #2
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Iv been wondering about that also
Gtkilrss is offline   Reply With Quote
Old 02-11-2014, 06:57 PM   #3
Cam8
Cam8's Avatar
Drives: 2014 Gray Camaro 2LT RS
You could just plastidip the whole thing and then peel the dip off of the bowtie... that would be the easy way
2014 Gray 2LT RS, 6M, Eibach Spings, Green Grill Light and Footwell Lighting
Cam8 is offline   Reply With Quote
Old 02-11-2014, 07:28 PM   #4
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
From my Note3
GbrilliantQ is offline   Reply With Quote
Old 02-11-2014, 11:19 PM   #5
WhitePhantomSS
WhitePhantomSS's Avatar
Drives: 2011 Camaro SS L99
how do you get plastidip to be smooth?
WhitePhantomSS is offline   Reply With Quote
Old 02-12-2014, 03:19 PM   #6
GbrilliantQ
¡ʇuɐıןןıɹq
Clean really well with alcohol. Make sure it's 60°+ outside and keep the dip bottles warm too. I do 4-5 coats first 2 are light. Keep pretty close to the car. The last coat is pretty heavy. The closer you are the better but you need to be careful of runs. It can run btw. I usually wait 30-40 mins before the next coat. The last coat peel the tape off as soon as you are down spraying to get a nice crisp line. If you wait the dip dries to the tape and it will pull up with the tape. This spring I'm going to dip the entire car matte clear. So it will end up being a matte orange. I got a graco hvlp for that though. I recommend searching for dipyourcar on you tube too.
From my Note3
Old 02-12-2014, 04:03 PM   #7
RedRaider2014
RedRaider2014's Avatar
Drives: 2014 Camaro RS 2LT
Plastidip is pretty forgiving. Remember the first coat will have about 50% transparency, wait about an hour then spray about every 20 minutes as many layers that you want. The more layers you put the easier it will be to remove (I recommend 4-5). Generally it dries pretty smooth. I haven't tried the glossifier but the black/white does at least. It would probably be easier to just tape around your lights, and paint over the bow tie, Allow it to dry completely then peel the dip off of the bow. There are a ton of videos on youtube
Billet Bowtie Replacement Insert
Rpi Splash Guards
Factory Zl1 Rear Splash guards
ZL1Rockers
RedRaider2014 is offline   Reply With Quote
