Old 12-25-2012, 04:20 AM   #1
gusmaro12
gusmaro12's Avatar
Drives: 2012 chevy camaro 2ss
Do i need an alignment if installing pedders front radius bushings??
so i purchased the pedders front radius bushings and i know that i need a press to take the old oem ones out, but my concern is do i need an alignment after this install?? Thanks
gusmaro12 is offline   Reply With Quote
Old 12-25-2012, 08:37 AM   #2
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
From the factory, those bolt holes are round. No adjustment can be done. I installed those myself as well, that is how I know. Pedders does offer eccentric bolts that you can make it adjustable if you want. You just have to slot the bolt hole and install the new bolts.
danvillekidd is offline   Reply With Quote
Old 12-25-2012, 10:02 AM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Short answer no, there is no factory caster adjustment at the radius arm so as long as the new bushing was made correctly it shouldn't change the length of the rod
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 12-25-2012, 12:17 PM   #4
gusmaro12
gusmaro12's Avatar
Yea i just want to know if i removed the whole arm and then alignment got messed up
Old 12-25-2012, 12:19 PM   #5
gusmaro12
gusmaro12's Avatar
After ur install did u notice a difference?? And from scale 1 to 10 was it that difficult to install??
Old 12-25-2012, 01:09 PM   #6
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
You dont need to remove the arm. Did mine a month ago and it took about 45 minutes. You notice them more when at highway or freeway speeds, no slop in the steering and you turn the wheel back and forth and the car follows
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900
Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600
Gen5Diy.com.....http://www.gen5diy.com/
Wretched Motorsports..www.wretchedms.com/
Pedders USA
...http://www.peddersusa.com/
bajamoon is offline   Reply With Quote
Old 12-25-2012, 01:34 PM   #7
gusmaro12
gusmaro12's Avatar
Did you do the pedders inserts? The ones i have are the pedders full bushings replacements
Old 12-25-2012, 01:44 PM   #8
bajamoon
bajamoon's Avatar
Yes, stage 3 which is the big insert. So yea you would take off the arm for that. You racing it? Didnt think many people boight the full replacement
My Build Thread
Pedders USA
Old 12-25-2012, 01:58 PM   #9
gusmaro12
gusmaro12's Avatar
I dont really race it but i go on cruises here and there and drive to work, i got them as a gift
Old 12-25-2012, 04:58 PM   #10
bajamoon
bajamoon's Avatar
Cool, free us always good
My Build Thread
Pedders USA
