JDP Motorsports
Old 08-06-2014, 10:39 PM   #1
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
Concealed Carry
Hey guys, I'll be 21 in a couple months and I'm going to be getting a CCW. Wondering about options on where and how to holster the gun with easy access from the driver seat, obviously. Also, this would *not* be the one carried on my person, it would be an entirely separate one strictly for my car. I know some of y'all have car guns, so how do you do it?
I had seen holsters situated under the steering wheel/dashboard, leaning towards that. Also seen people squeeze it between the seat and console, but frankly I don't want a passenger to even know about it.
Recommendations?
Synyster is offline   Reply With Quote
Old 08-06-2014, 10:43 PM   #2
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
Might try the Firearm section.......I did not even know we had a Firearm section until recently when a thread was moved.
http://www.camaro5.com/forums/showth...88404&page=247
Tenring is offline   Reply With Quote
Old 08-06-2014, 10:46 PM   #3
Synyster
Synyster's Avatar
Why would this be locked? It's a question... regarding Camaros, specifically...
I know there's a firearms thread, but that's not what I'm asking.
Old 08-06-2014, 10:47 PM   #4
Tenring
Tenring's Avatar
Same question awhile back was moved, not locked.
Old 08-06-2014, 10:49 PM   #5
Synyster
Synyster's Avatar
Oh. I guess I should've searched then. Well if it gets moved, it gets moved then.
My question as to it being locked was directed towards the other guy trying to be cheeky saying "in before the lock."
Old 08-06-2014, 11:18 PM   #6
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
I use my carry gun for the car aswell...when im in the car it goes in the center armrest/console...i dont trust leaving a fire arm in the car when im not in it...have had previous cars broken into and dont want to risk a firearm being stolen...
When thinking of placement, test it out...i couldnt do it under the steering wheel cause it was too much trouble pulling it up quick enough to use if needed...steering wheel was in the way for me...
13blackLS is offline   Reply With Quote
Old 08-06-2014, 11:35 PM   #7
Synyster
Synyster's Avatar
I hear you. I'll be new to this so I figure I'll learn the best way for me as I go. I wouldn't be leaving any firearms in it indefinitely though either. My console is rather full too, no way I could fit something else in there. Maybe the door pocket? Or somehow forward of the console on the side of the 4 pack gauges... trying to avoid putting it inside of something I'd have to open first.
Old 08-07-2014, 03:26 AM   #8
thkfast
thkfast's Avatar
Drives: '14 Red 2SS/RS/LS3
I recommend the "Fast Draw Quick Draw Gun Magnet". You basically screw this powerful plastic-coated magnet somewhere and your gun sticks to it upside down, sideways, however you want. It can hide a gun completely out of sight in the most unsuspected location. Assuming you have a gun already on you, your car gun can be up under a seat or under the dash. You sound cautious about the placement as well you should be. Good luck.
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
thkfast is offline   Reply With Quote
Old 08-07-2014, 09:17 AM   #9
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
My XDM40 fits perfectly in the holster in came with and sits in the small gap under the steering wheel.
ECS blower kit, Alky Control meth Injection, RPMtransmission 4L80E, QTP cutouts, line lock, Circle D converter, GPI modified LS3 intake manifold, BoWhite PTB, ARH LTs/exhaust, TSP VVT3 cam and ported heads, SLP 160 Tstat, NGK TR55 plugs, ADM FPCM, dual pump, ID1300 injectors, flexfuel sensor, 18" wheel setup, ZL1 3.73 differential, DSS 1-piece aluminum drive shaft axles, Koni yellow shocks/struts, BMR Suspension…FOR NOW.
ticowarbird is offline   Reply With Quote
Old 08-07-2014, 09:35 AM   #10
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Drives: My wife crazy!
+1 XDs45 here. The OWB molded paddle holster mine came with slides in the slot right under the steering wheel in the gap. I put it there while putting around town and put it in my comp tac iwb when I get out. I don't feel comfortable leaving it in the car without me in it. Our cars are picked out to be broken into for some reason. Like we have a lot of money or something which we did but we spent on modding our camaros.
With that said, it shifts during hard cornering or acceleration so keep that in mind. I have been searing for a fixed position for it and haven't found the right spot.
M3hta1 is offline   Reply With Quote
Old 08-07-2014, 11:18 AM   #11
SSBOT
SSBOT's Avatar
Drives: 2010 SS Transformer, '99 C5 Vette
Anyway you could post a pic of how the paddle holster goes in there?
Thanks
SSBOT is offline   Reply With Quote
Old 08-07-2014, 11:32 AM   #12
RedRaven
RedRaven's Avatar
Drives: 2012 2SS M6 CRT
Just remember it has to be "concealed" as in not visible from any outside angle. If someone standing by your driver's window can see it, it's not concealed. I would suggest under the front edge of the driver's seat, although I haven't investigated that fully yet. My M&P40C fits easily in the center console if it's empty enough. Otherwise, the glove box will fit a full size easily. Generally if I'm carrying in the car it's just behind my right hip. If it get's uncomfortable, it goes in the console or glove box.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties
First real car: 1968 Malibu, '67 283, Canary yellow
RedRaven is offline   Reply With Quote
Old 08-07-2014, 11:41 AM   #13
Fraxum
Fraxum's Avatar
Drives: 2018 A10 ZL1
OP There is a spot right next to the front seat. When you are driving your right leg covers it up.
Old 08-07-2014, 11:53 AM   #14
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
Drives: Black 2014 2SS/RS
Dang...that's some good photoshop mojo there
...Nothing is True, Everything is Permissible...
2Fast4Mu is offline   Reply With Quote
