06-07-2010, 10:05 AM | #1 |
Making magnaflow exhaust louder?
I just put a Magnaflow exhaust street version on my Camaro and realized it's not aggressive as I wanted it to be...any suggestions on how to make it more aggressive without wasting to exhaust that I've already purchased...I heard alittle about the X pipe and the H pipe....any suggestions?
06-07-2010, 10:32 AM | #2 |
Dances With Mustangs
Cross pipe would help sound but also improve the efficiency of the system. Definitely get the x pipe. Do you have a cold air intake? If not, I'd recommend the Cold Air Inductions intake; top quality, easy to install, looks great and sounds great. And it not only improves the sound but adds a bit of power too.
http://www.camaro5.com/forums/showthread.php?t=68894 That isn't my install but it shows the system. Oh and welcome to the Camaro family and to Camaro5.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
06-07-2010, 11:59 AM | #3 |
Rumbly Bumble Bee
Drives: 2010 2SS Camaro Join Date: Aug 2009
You shoulda gone with the Magnaflow "Competition" axle back. It's a fancy muffler delete. You're not gonna get the sound you want unless you go with a muffler delete or more agressive muffler like the Borla Atak.
Take your system off and sell it. Then buy another system.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW! |
06-07-2010, 12:06 PM | #4 | |
Drives: '69 SS Convertible Join Date: May 2009
Add some long tube headers and a tune and it will fix things. I you don't want to go LT for now then your best bet is to sell the system for a small loss and use that money towards the 2.5" Comp Series cat-back. Check with www.MagnaflowPlus.com for the best pricing. Call them and let them know you're with Camaro5...don't go by the prices on their web site.
Build Journal |
06-07-2010, 01:01 PM | #5 |
Drives: 2010 Camaro Join Date: May 2010
there are many ways to make your exhaust louder.
new headers can make it louder, xpipe or H pipe(just patterns of the pipes), remove cats and or resonators, or muffler delete. |
06-07-2010, 03:32 PM | #6 | |
Drives: Callaway Rogue Join Date: Jul 2009
And take out the factory crossover and put in the magnaflow tru x-pipe. That will make it louder. the x pipe is like 75 bucks. |
06-07-2010, 05:16 PM | #7 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I would keep it the way it is and save your money for Long Tube headers. Once you add long tube headers and high flow cats, you'll love the sound.
06-07-2010, 10:35 PM | #8 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Take it from 2 guys with the exact same system. Put LT headers on and it will sound like a beast at WOT. If its still not loud enough than you can replace the muffler X pipe with a non muffled x pipe. If you dont want to get LT headers than I would suggest Solo high flow cats and replace your current x pipe with the non muffled x pipe. Do not sell your system to get more sound as I think you will lose some money in the deal when you can just tweak the current setup to your liking.
07-02-2010, 08:12 AM | #9 | |
07-02-2010, 09:22 AM | #10 | |
You really only have a few options if you really want your sound: -Best option would be to add a set of LT headers and a tune. -Sell what you have and get the 2.5" comp series exhaust. -Sell what you have, put the factory exhaust back on, get a muffler delete and add an x-pipe to that. -Cut out your street mufflers and add straight pipe.....but that would truely be a waste.
Build Journal |
07-02-2010, 09:35 AM | #11 |
Rumbly Bumble Bee
She's got the axle back.
07-02-2010, 09:40 AM | #12 |
Ok....never saw that in the posts.
Another thing I thought that would probably work perfect would be to add some High Flow cats. That should bring out the sound and not have to do a tune unless you want. Look at either JBA HF Cats or SOLO HF Cats.
Build Journal |
07-02-2010, 04:03 PM | #13 |
Drives: SuperSport's Join Date: May 2009
Cam & headers with no cats = problem solved
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD" Plans : 2013 CamaroSS 1LE |
07-02-2010, 04:29 PM | #14 |
Drives: 625 rwhp red jewel ss COTW 11-8-10 Join Date: Oct 2009
Here is the video of my exhaust. This is the stock / then over to the 3" magnaflow system with ARH long tube/ high flow cats/ X pipe. The last video is running through 1 2 3 gears then WOT in 4th.
Thread Tools | |
Similar Threads | ||||
V8 Camaro Aftermarket Exhaust Video Clips Compilation | tjbusa | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 591 | 07-06-2022 08:38 AM |
Magnaflow Stainless Steel Exhaust @ Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 2 | 01-28-2011 02:23 PM |
For Sale: 2.5" Magnaflow Catback Exhaust | ad1horne | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 04-19-2010 06:03 PM |
Which Exhaust SLP Loudmouth 1 or Magnaflow | Medic726 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 26 | 04-03-2010 07:47 AM |
EXHAUST | Milk 1027 | Wiki | 2 | 03-07-2010 09:20 PM |
