11-27-2012, 04:13 PM | #1 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
pfadt bushing removal tool
anyone have one they want to sell?
I was thinking a socket and a bfh...was I wrong?
-John S.
11-27-2012, 04:21 PM | #2 |
Drives: 2011 cyber grey metallic camaro v6 Join Date: Jun 2011
No I have seen using a bolt and socket method for installation and removal on the show wheeler dealers. Idk if you have seen it cuz its on velocity channel. I was thinking about using that method for some pfadt diff bushings
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
11-28-2012, 03:28 PM | #3 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
The Pfadt tool is only $30 new and it's not commercial grade. It does a great job and is definitely worth it for the trouble you save, but those OE bushings are in there!
By the time mine was done pulling 2 out, I wouldn't trust it to pull 2 more! IMO the best idea is to just get a new one. |
11-28-2012, 03:39 PM | #4 |
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally Join Date: May 2012
I ordered one to use and once I see it I will just make my own from then on out...I am a machinist so it looks pretty easy
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
11-28-2012, 03:44 PM | #5 |
Maybe you could build one from some heavy pipe and a bolt and washer combo. Thats was what I was planning to do next month so if you do it and it works let me know.
11-28-2012, 03:48 PM | #6 |
The Machinist
I'm thinking 316 stainless steel for the plate, heat treated all thread, and 4130 for the hammer part. That way when the hammer goes bad all you have to do is replace that part and the rest will last forever.
11-28-2012, 03:51 PM | #7 |
The Machinist
Prolly put a Teflon sleeve inside the hammer too and heat it up to stick then it won't damage the threads
11-28-2012, 11:24 PM | #8 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
The Pfadt tool is $30 and if you buy it with the arms you get free shipping!
Kind regards, Jordan Priestley 888.308.6007 |
11-29-2012, 06:47 AM | #9 |
Banned
Drives: 10' 2SS LS3 M6 Join Date: May 2012
a little rigid conduit, some threaded rod a few nuts and you have the pfadt tool.
11-29-2012, 03:22 PM | #10 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
make your own tool for about $8 at the hardware store, add some heat and the bushings come out easy.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
11-29-2012, 05:36 PM | #11 |
Drives: cars Join Date: May 2011
Or get a 3 piece 2 jaw puller set for $20 and have more tools that are useful for many things forever. Took 5 minutes.
11-29-2012, 08:00 PM | #12 |
instigator
Yeah...I'm doing what synner said.
-John S.
