12-24-2013, 11:25 AM | #1 |
Drives: 2013 SS/RS LS3 NPP/Hurst Join Date: Oct 2012
Tire Pressure Sensors Crossed
I have a 2013 2SS M6, just discovered my rear TPS are crossed. The readout on the dash for the left rear is actually the right rear, and vice-versa. Is this
something I can fix, or do I need to take it to the dealership? Thanks! |
12-24-2013, 11:35 AM | #2 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
try doing a reset.
Full instructions are in the manual, but basically you switch to the TSP display then hold in the reset button, The left front blinker will turn on and the horn will chirp, go let out 3-5 psi from that tire (left front). When the horn sounds again, go to the right front and repeat, then rear passenger, then finish with the rear driver's side tire. the system will honk the horn twice indicating that you have reset the system. If this doesn't work, you may need to switch the sensors back.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
12-24-2013, 11:35 AM | #3 |
Let's go Rangers!
You can rotate the tires side to side, that's what I'd do. Did you have a dealer oil change lately, they may have rotated the tires without reprogramming them.
Or just run to a dealer for a reprogram as the manual process does not work on the 13's unless you have the relearn tool. Last edited by nyrfan; 12-24-2013 at 11:46 AM. |
12-24-2013, 11:42 AM | #4 |
I did have the tires rotated...I bet thats it! Thanks guys.
12-24-2013, 11:44 AM | #5 |
Let's go Rangers!
12-24-2013, 11:44 AM | #6 |
OK, I just checked, and the manual for this model says that you need a special "relearn" tool, you may have to go to the dealer
http://www.chevrolet.com/content/dam...k13camaro1.pdf page 10-61 and 10-62
12-24-2013, 11:45 AM | #7 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
12-24-2013, 11:51 AM | #8 |
Let's go Rangers!
Actaully I beat you both to it, LOL.
12-24-2013, 12:44 PM | #9 |
I just went out to the garage and rotated the rear tires. Gave the wheels a good cleaning as well. My floor jack will not go anywhere under the front of the car though.
12-24-2013, 12:58 PM | #10 | |
376 cubic inches of fun
But if the dealer rotated your tires without reprogramming the TPS, he owes you. Also, you can buy the tool. http://www.amazon.com/Kent-Moore-EL-...pms+reset+tool |
