06-08-2011, 06:11 PM | #1 |
Iroc-Z <3'r
Drives: '87 5.7L Iroc-Z Join Date: May 2008
'87 IROC-Z Rim size - Help?!
I contacted someone selling Iroc rims, he says they Are Aluminum 16", however he says two of them are 8" wide, and two are 10"...
this doesn't seem correct, as I thought I read they are all the same width...(even tho the difference does make sense) Can someone please clarify per Factory original?, I currently have 91/92 z28 rims on the car. thanks in advance!
"Camaro Z/28 is back. Gentlemen, Don't even bother to start your engines." |
06-08-2011, 06:34 PM | #2 |
army life
Drives: 2018 hyper blue zl1 Join Date: Feb 2011
i have had several irocs and they were all the same width size and they are 16's there are many aftermarket iroc rims you can buy
06-08-2011, 07:38 PM | #3 |
i have an 87 iroc the rims are all the same width front and back but the offset is different for the front and the back. the rims say front or rear on one of the arms so they are not mixed up during install
06-08-2011, 09:50 PM | #4 |
Iroc-Z <3'r
thanks again all for confirming 16 x 8. - I appreciate it.
this guy wants to sell 16 x 8 in the front, 16 x 10 in the rear. (apparent aftermarket aluminum Iroc rims, 85-87 style) - Will the 16 x 10 work in the back? or is that too wide for the car?..
06-08-2011, 11:05 PM | #5 |
Drives: '90 RS 427ci LS-1, '86 IROC 305 TPI Join Date: Apr 2011
Depends on the offset. I believe the correct offset is 5 inches (Backspace.) However, for the correct answer I would confirm at www.thirdgen.org Check their boards. This topic gets a lot of attention. t is possible to get 12" wide wheels to fit the rear.
Similar Threads | ||||
OEM tires and rim size tolerances | Wgrenon | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 05-24-2011 12:02 PM |
Whats my exact rim size? | JBuzzy11 | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 05-15-2011 04:27 PM |
Biggest size tire and rim on 1LT.....20? 22? | skysharker1 | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 03-25-2011 11:40 AM |
Size and fit question | melody301 | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 03-23-2011 12:35 PM |
