11-03-2022, 06:34 PM | #1 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Octane Booster
Hi All, only Premium available here in my area of Az. is 91 octane, This is the minimum Chevrolet recamends for our ZL1s and I think SS , I want to at least take to 92 to 93 . 2oz. makes 1 gallon of 91 octane to 95 octane , 1 oz = a little over 92 octane . I know the ECU will adjust to accommodate the minimum, but didn't want to be up on the knock sensor or sensor's.Ive been doing some research in the different brands of Octane Booster , VP, 104 plus , Turco, Lucas, ect , I am leaning towards this product . I did purchase a 16 oz can to try, Has this product been used by any of you ?, or post what you have experience using. Thank you
2023 ZL1 A10 Shadow Gray Metallic
11-03-2022, 07:06 PM | #2 |
Drives: 21 ZL1 Join Date: Feb 2022
I've been using VP Octanium the unleaded version. Autozone stocks it. I treat a full tank of 93 and have completely eliminated the knock I was seeing. It did turn the plugs orange but the car runs well.
https://vpracingfuels.com/product/oc...nleaded/?c=207 |
11-03-2022, 08:55 PM | #3 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Used Torco for years on a high boost turbo motor. Turns your plugs orange. Works well.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-03-2022, 09:29 PM | #4 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Same here, I used this exact Race Gas product (32 oz bottle) for drag racing in the summer heat back when the car didn't have flex fuel capability, and it worked fine, eliminated all knock.
Orange residue is a side effect, but I didn't run the booster long enough or frequently enough to cause harm, whether or not it's actually as harmful as claimed by many.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
11-03-2022, 09:38 PM | #5 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Boostane is commonly used by the boosted Mystang crowd
I used it as a precaution also Sometimes you just don't know if the gas is going to be up to par I bought 3 big bottles of Boostane off Amazon Use about 1/4 a bottle every fill up Daily driving it adds up
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
11-03-2022, 09:48 PM | #6 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I’ve used Boostane in the past with good results too. No complaints here.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
11-03-2022, 10:34 PM | #7 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I use Torco, no issues here, they all basically do the same thing.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
11-04-2022, 06:56 AM | #8 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I prefer the one use bottles to save me mixing stuff but I've only needed it a few times, carry a few bottles in the trunk if I have to get a tank of 91 for an unplanned need.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
11-04-2022, 07:07 AM | #9 |
Petro-sexual
I've used that same Racegas to a full tank of 91 and had great luck.
I'm trying Boostane, to which many swear by, too, and add about 2.5oz per full tank, and it seems to be doing about the same as the Racegas.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
11-04-2022, 07:48 AM | #10 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Been using Boostane for years...I typically buy a 5gal drum direct from Boostane when they run their specials...Typically 20-30% off with free shipping.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
11-04-2022, 09:47 AM | #11 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I've been using that product since tank # 1 with 8,000 miles with no ill effects. I find the 2 sizes that it's available in to be extremely convenient. The small size for a half tank and the big size for a full tank. I order mine from Summit.
2018 ZL1 1LE - Red Hot, Nav, PDR
11-04-2022, 11:03 AM | #12 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
All the octane boosters will foul or build up orange crud on spark plugs. If you can afford it and it’s available in your area, blending actual race gasoline with pump gas will be your best bet. That’s what I do. During summer I’ll blend 1 gal of 100 octane unleaded with about 5-6 gals of 91, since that’s all that’s available here. That gets it to about 92.5 octane. If it’s really hot or I know I’m going to do some pulls I’ll throw in an extra 1/2 gal of 100 octane. During winter the cold temps don’t require as much octane so I’ll use 1 gal of 100 octane to 8-9 gals of 91. It’s not cheap, and is sort of annoying if there’s no 100 at a pump. I use Sunoco 260GT, have to buy 5 gallon pails, and transfer 1 gallon at a time via a gas can. $17/ gal right now. Labor of love.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
11-04-2022, 02:46 PM | #13 |
Thanks guys, I used 104+ way back 1979 when I first started Drag racing, turned plugs yellow , and had to change often(don't know if changing was an effect of booster) then started using Race gas as future motors had more compression. I don't want to mess with plugs on the Camaro. I kinda figured all booster will discolor the plugs , and maybe deteriorate the plugs . Cooler weather in the Desert now til next March / April I have time to figure out what I want to use .
My question to the user's of Boostane, does it discolor the plugs and any noticable deterioration to them.
11-04-2022, 03:39 PM | #14 |
Just pulled my plugs to check them out since using the VP Octanuim through two tanks. They were completely orange as people say. Through TWO TANKS of gas.
