12-19-2016, 03:02 PM | #1 |
Drives: Black 2010 Camaro SS Join Date: Nov 2016
Catless downpipes ?
So I was looking around for my next bolt on buy and I was thinking about high flow cat down pipes , but I found catless down pipes . Just wondering what the difference is and if anybody has had them . Here's the website https://m.summitracing.com/parts/hok-70701309rhkr
12-19-2016, 03:21 PM | #2 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Catlessdown pipes are just that, no catalytic converter or resonator. This will cause you to lose low end torque and gain a couple hp ar the high end of the rpm scale due to no restriction from the converter or resonator. High flow cats have less converter cells to in crease flow and free up your exhaust. Some like the Solo brand have a resonator built in, some like the ARH hi flow do not. If you go catless you must get the resonated magnaflow xpipe , as catless will be very loud and raspy. The xpipe will tame most of the rasp but not all. If you get a hi flow with the resonator you won't need the xpipe ,if you get the high flow without the resonator you will need the xpipe. The high flows will free up the exhaust and let your engine breath better.
12-19-2016, 07:31 PM | #3 | |
12-20-2016, 02:51 AM | #4 |
I would say the hi flows are the better of the two. You won't lose any low end torque, you won't have the smell of unburned fuel, and if you go catless you will definitely fail an emissions test.
12-31-2016, 01:39 PM | #5 |
Catless, go big or just don't do it..
You want loud |
01-02-2017, 09:50 AM | #6 |
Drives: 2022 Cheverolet Camaro RS V6 Join Date: Nov 2016
Good luck getting it to pass inspection without Cats if you live in an Emissions Inspection area.
Tx12Camaro
2022 Camaro V6 1LT RS |
01-02-2017, 09:46 PM | #7 |
01-09-2017, 02:09 PM | #8 | |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
I had high flow cats, then went catless. The catless are loud and annoying...but do help on the top end.
I do miss the high flow cats, but being boosted, cant run them. Did not notice much difference other than a little low end with the high flow cats....noticed more of a difference with catless, but, again, its LOUD. And the sound is insane.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
01-09-2017, 02:38 PM | #9 | ||
Magnaflow cat back exhaust, ARH high flow cat downpipes, 80mm throttle body, K&N cold air intake, ported intake manifold with spacer, elite e2 catch can with clean side separator, overkill e85 flex fuel kit, overkill tune.
01-09-2017, 03:28 PM | #10 |
It's not trents or Jonathan's car but right now it's sitting around the 460 mark. Still have plenty of room on the pulley to go and e85 here soon with some cams.
Possibly a different boost setup too ;-)
Sponsors:
01-09-2017, 05:56 PM | #11 |
way more power than mine thats for sure!! haha
