06-16-2014, 05:39 PM | #1 |
Red plastidip taillight bezels and interior
Had a litter time a wanted to change the look a little.
Sent from my SAMSUNG-SM-G900A using Tapatalk |
06-16-2014, 05:39 PM | #2 |
*little
06-16-2014, 06:27 PM | #3 | |
Drives: Yellow 2014 2SS RS 1LE W/ RECAROS Join Date: Aug 2013
Looks good, I had everything black except for the air conditioner bezel. I finally got that off last night and did it.... That was not the easiest task for such a small piece. |
06-16-2014, 06:33 PM | #4 |
I can't figure out how to remove that or the center console
06-16-2014, 06:51 PM | #5 |
06-16-2014, 07:00 PM | #6 |
For the air vent bezel... You have to remove the long strip above it ( The one you dipped black it looks like ) there are then 6 screws under that remove those... On the right side there will be a piece of the leather trim loose. Pull that up and remove the whole large center piece you have to pull with a bit of force to get it off. The vent will be connected to that you then just unscrew the necessary screws to get the vent off , Disassemble the vent and pop the plate off. Just follow steps in reverse to put it all back together. Its really not that hard once you do it the first time. Putting it back together took me a whole 3 minutes once i knew what i was doing.
Maybe someone can reference the topic that shows the DIY to remove this with the instructions? I used it yesterday and can't find it now. |
06-17-2014, 09:44 AM | #7 |
06-17-2014, 09:46 AM | #8 |
Thanks for the help
06-17-2014, 11:10 AM | #9 |
A few more mods today
06-17-2014, 12:44 PM | #10 | |
It's easy I get my fingers under the plate on the front side where it faces the cup holder and just pull it straight up. Once you pop the first clips move your hands under and push/pull up to get in a little closer to the clips. Sent from my iPhone using Tapatalk |
06-17-2014, 04:05 PM | #11 | |
Drives: Blue Ray 2SS Join Date: Jul 2013
Front Floor Console Front Cover Replacement (With UMQ) Removal Procedure
Good Luck, Paul |
