07-07-2013, 10:11 AM | #29 |
I just emailed Schroth. There website says the Rallye 4 should be used in all cars that when the rear straps are attached they create at least a 45 degree angle. If the angle is too tight then use the Rallye 3. I have no way to test out either. I thought someone on this forum was using the Rallye 4 kit.
Also, isn't running a 5 &6 point harness illegal witout a roll bar? Because in a roll over you won't slip out and are prone to neck and head trauma or worse compared to a 4 point with ASM or stock 3 point which let you mOve around. This is what I have read elsewhere.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. Last edited by toehead93; 07-07-2013 at 10:48 AM. |
07-07-2013, 11:22 AM | #30 | |
When i was getting all the info i needed to make my decision,i was going to have to have someone cut holes in my floor and weld anchor points for my belts.Whether you go with 4,5or 6pt,it has to have somewhere to anchor,and this is what the tank plate is for.As you know it's totally bolt in and no holes were drilled. Pic#1 is how my shoulder part is attached Pic#2 is how the 2 side,and crotch parts attach,whether it's a 4,5,or 6pt there has to be an anchor point.
07-07-2013, 11:46 AM | #31 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Damned if I know why the driver of the Boss wouldn't want to talk. If I was him, I'd appreciate any feedback that might help. I did see it suddenly turn in a whole lot more sharply in the left hander in the video - any chance you know who it was (I may know him from some Mustang forum). I think I know what else you saw, too. Norm |
07-07-2013, 12:39 PM | #32 |
The bad thing with a 5 &6 point hsrenss with no roll over protection is when the roof collapses your body is held in place so your head and neck will be next. A 3 point or 4 point with ASM will allow your shoulders to slip out so you don't get crushed.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
07-08-2013, 02:29 PM | #33 | ||||||
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Sorry, was offline a few days so I will try to catch up.
-Matt
07-21-2013, 05:17 AM | #34 | |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Sent from my iPad using Tapatalk HD
