05-16-2013, 11:32 AM | #1 |
Drives: 2012 45th anniversary Join Date: Apr 2012
Rear end gear break in ????
We are trying to decide on doing the 391 gear swap in our car. Gonna send it off and have cam and gears done at same time. The shop i am using is going to just replace the rear end with a new unit loaded with the 391's. my question is do you have to do the whole break in thing of several heat cycles with a built unit like i have read others do when they have just replaced the gears?? Any help or info would be appreciated. The shop we are using is 500 miles from home and if i have to kill off 2-3 days breaking in my mew gears i may decide to just do the cam. Thanks.
05-16-2013, 11:58 AM | #2 |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
Lingenfelter put new 3.70 in mine and I drove it 600 miles home with no issues. They did say to try and not stay at one speed for too long, and not very high speeds to begin with, but I thought that was more for the engine (Which was forged internally amongst other items).
The shop doing the work should be able to answer your question.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
05-16-2013, 12:04 PM | #3 | |
05-16-2013, 12:11 PM | #4 |
376 cubic inches of fun
Actually, break in is more for the gears than for the engine. Vary speed and stay away from WOT for the break in period.
05-16-2013, 01:02 PM | #5 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Vary the speed so one part doesnt get worn more than the other. No cruise control
05-16-2013, 01:11 PM | #6 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
I read about a whole involved procedure, but it seemed like overkill. The shop that installed mine just said go easy on her for a little while. That's what I did, and I haven't had any problems. The real hard part is resisting the urge to smash that go pedal!
05-16-2013, 02:49 PM | #7 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
You definitely want to break in those gears properly...Then manufacturer website should have step by step instructions...You'll want to turn the radio off and listen for noises as well.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
05-16-2013, 03:14 PM | #8 |
Thats a good point i think it will be an rx brand diff. So ill try and check with them as well
05-16-2013, 09:39 PM | #9 | |
I'm not sure why there's such an elaborate procedure for breaking in gears. The car comes from the factory with brand new gears, right? You don't have to follow any special procedures when leaving the car lot, except the usual break-in stuff.
I found this in an old thread: Quote:
I'm not an expert on this, but I didn't follow this procedure, and my gears are peachy.
05-16-2013, 10:00 PM | #10 | |
05-16-2013, 10:52 PM | #11 |
WHAT RED LIGHT?!
Here's some good info on the importance of breaking in new gears:
http://www.ringpinion.com/technicalh...r_Break-In.inc I know it specifies trucks but the reason for break in is the same
05-16-2013, 11:31 PM | #12 |
Drives: 2010 Camaro 2SS/RS CGM Join Date: Jul 2011
Took my 1le gears somewhat easy first 500 miles. I slam on them all the time now. No whine, just great acceleration.
Pat
2010 2SS/RS M6 3.91's, TSP Longtubes, SWG Tune, Vararam, and a heavy foot |
05-17-2013, 03:40 PM | #13 |
Drives: 2010 2SS Join Date: Jan 2011
Did you break in the factory gears? If they are set up properly, don't worry and drive it.
06-22-2013, 03:41 PM | #14 |
Dean Voss
1LE 391 gears
I had the 1LE gears installed from a friend who does truck gears. I installed a JRE posi upgrade kit with billet end caps. After 100 miles I pushed it hard in the first three gears and the rear sounds great with no noise and no problems.
