09-20-2015, 02:59 PM | #1 |
Canadian
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2013
Hanging around 2000 rpm till stopped
Hey guys/Gals,
Slight problem, I cleaned my throttle body on friday evening and took it for a drive yesterday, what is happening is that it idles fine, drives alright till I take the car out of gear in which case it hangs at 2000 rpm until the Speedometer reads 0 than it tanks back down to 850-900 rpm and idles again. I used Throttle Body Cleaner to clean the Butterfly and may have pushed it open a little bit by my hand while wiping it down. Does anyone have any ideas what i can do to bring it back down to regular driving and such.
2011 Camaro SS/RS
--------------------------------------------------------- The cars we drive say a lot about us. |
09-21-2015, 09:27 AM | #2 |
BUMBL Z
i thought that after cleaning your throttle body, you're supposed to let it idle for 10-15 minutes to let it relearn?
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
09-21-2015, 09:43 AM | #3 |
All About That Speed
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
It looks like you have a cam according to your sig...if so, then the problem probably isn't mechanical, it is in the tune. More than likely your coastdown idle proportional and integral airflow tables aren't set up properly.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR |
09-21-2015, 10:05 AM | #4 |
Canadian
Spadz93 - I let it idle for 10-15 minutes and in that time it idled just like normal, I ended up driving it the day after and that when I noticed the hanging RPM,
SNSSTR- I can see where you are coming from, although before I cleaned the throttle body it was running Great, Only reason I cleaned the throttle body is that the when I removed my cold air intake to clean it out I noticed that the butterfly valve was covered in carbon and cleaned it up and have had this problem since, I am going to email ted and see if he knows any work arounds on this problem.
2011 Camaro SS/RS
09-21-2015, 10:16 AM | #5 | |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
09-21-2015, 10:33 AM | #6 |
Canadian
The MAF was pulled prior to cleaning and set aside
2011 Camaro SS/RS
09-21-2015, 04:46 PM | #7 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Did you clean it on or off the car? If you left it on the car, you may have sprayed the MAP sensor which is right behind and to the left of the throttle body.
2010 Camaro SS LS3 - No Modz
09-22-2015, 07:53 AM | #8 |
Canadian
I took it off the car to clean it, I did how ever not replace the throttle body o-ring, that should be here today for replacing, I will also try to get the map sensor out to try and give it a good cleaning.
2011 Camaro SS/RS
09-22-2015, 08:15 AM | #9 |
It sounds like you're very particular so I doubt this is it...did the vacuum hose come off the intake tube or valve cover?
09-22-2015, 08:49 AM | #10 |
Canadian
I pulled that hose off and replaced it with a new hose as it was starting to look bad.... so its not that. Im thinking I may have pinched the throttle body o-ring, but it still drives other than holding the 2000 rpm. Mr. Jannetty thought It may be a vacuum leak and I can see where he is thinking it is. but I can also see where I may have to force a relearn on my throttle.
2011 Camaro SS/RS
09-22-2015, 09:00 AM | #11 |
Definitely, maybe just disconnect the battery for 30 minutes or so to let the computer reset?
Throttle body o-rings just don't usually go bad
09-22-2015, 10:11 AM | #12 |
Canadian
I was just taking a look anything that could cause a vac leak or something similar and it dawned on me that the Previous Owner installed the Throttle body Spacer....... now get this I found it kinda strange but never thought anything of it that there is a complete LACK of gasket on either side of the spacer...... hmmmmmmm so after work gonna pull the spacer out and see if that helps me at all..... if it does well that'll be problem #2 that I have had to fix on it from him.
2011 Camaro SS/RS
09-22-2015, 12:21 PM | #13 |
Sounds like you may have found the issue! Let us know
09-22-2015, 06:04 PM | #14 |
Canadian
so just removed the T.B. Spacer as well as the throttle body oring as a precaution, nothing has changed..... back to the drawing board
2011 Camaro SS/RS
