03-14-2016, 04:22 PM | #1 |
Drives: 2013 camaro Join Date: Mar 2013
Brake Upgrade
Hello Everyone,
Does anyone have a comprehensive list of the hardware needed to successfully complete the brake upgrade (v6 to brembo). I have searched the threads but none show part numbers besides these two being 11570788 and 11515781. It stated I needed 4 EACH of those bolts. Can anyone confirm this? Also is there anything else I may need? Thanks |
03-14-2016, 08:47 PM | #2 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I don't know the comprehensive list but you could check out the V6 Brembo upgrade in the Chevrolet performances catalog. They list out all the individual pieces and GM part numbers.
Here's a copy of the page out of the chevy performance catalog with the V6 Brembo Brake upgrade.
03-15-2016, 11:08 AM | #3 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Calipers, rotors, pads, and lines.
I then did the SS Master cylinder, made a huge difference in pedal feel.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
03-15-2016, 11:33 AM | #4 |
Derek,
Do you have part numbers for the caliper bolts, I keep getting conflicting pn's I got the calipers and lines and getting the rotors, just the pn on the bolts to hold them down, and pin kit information. |
03-15-2016, 11:34 AM | #5 |
the bolts are the same as the stock ones. You can get the part number from GM Parts Direct if you need them. I just re-used my bolts.
Sponsors:
03-15-2016, 06:29 PM | #6 |
Drives: 2011 White 2SS Join Date: May 2011
Those caliper bolts are a one time torque-yield (angle) bolt. Some have gotten away with reusing them with locktite but they are less than $5 each. Replace them!
Once they are properly torqued they are stretched. Sent from my iPhone using Tapatalk |
