Old 10-04-2017, 11:33 AM   #1
siriusdish
Drives: 2010 Camaro L99
Ignition Coil
Had a ignition coil replaced, car runs fine then started acting up again. But then shut car off and restarted and runs fine again, AFOM said once one Coil goes bad then the other ones are not fare behind. Should I replace the other 7? Engine Light Is Not on.
Got the other coils. will see if its fixed...
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
