#Camaro6
Old 11-03-2021, 05:11 PM   #1
Singhparmvir98
Drives: 2017 Camaro ss
Does anyone know what this part is? (Oil leak)
Hey I am new to this forum but I had a question regarding my car. I have a 2017 Camaro ss and I noticed that it has an oil leak. When I went under the car I noticed that it was leaking from this part but idk what it is called and why it happened. If someone could tell me what the part is called and how to fix it that would be much appreciated. The leaking is coming from on the side of the oil plan from that nut as shown in the photo. Thank you and please let me know.
Singhparmvir98 is offline   Reply With Quote
Old 11-03-2021, 05:37 PM   #2
Jeb114
Jeb114's Avatar
Drives: 2021 300
Pull back so we can see where on the car your looking at.
Jeb114 is offline   Reply With Quote
Old 11-03-2021, 05:50 PM   #3
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Engine oil cooler
Warrior102 is offline   Reply With Quote
Old 11-03-2021, 06:00 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Put a wrench on that bolt and see if its tight. That is the Engine oil cooler.
lt4camaro is offline   Reply With Quote
Old 11-03-2021, 06:08 PM   #5
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
That's the water-to-oil oil cooler, to be more precise. SS has additional air-to-oil oil coolers in the front but that's beside the point.
As others said, check the bolt's tightness. If the bolt's tight then it's either a gasket or something is cracked somewhere.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 11-03-2021, 06:11 PM   #6
Singhparmvir98
gotcha thank you everyone, is it easy to replace the gasket on these or no?
Old 11-03-2021, 11:13 PM   #7
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
If I’m not mistaken, the dip stick is right above that…. I’d make sure it is seated correctly if have removed it in the past to install headers or whatever.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 11-04-2021, 08:20 AM   #8
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
If you're referring to the "auxiliary engine coolant cooler and rear differential oil cooler", that's coupe only. If you're referring to the "extra-capacity cooling system and external engine and transmission oil coolers", that's auto transmission only. In other words, my car (convertible, M6) has neither.
ember1205 is offline   Reply With Quote
Old 11-04-2021, 01:18 PM   #9
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Besides the nomenclature get a wrench on it and see if it's tight.
WhiteMale is offline   Reply With Quote
Old 11-04-2021, 02:08 PM   #10
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
Originally Posted by Singhparmvir98 View Post
The leaking is coming from on the side of the oil pan from that nut as shown in the photo. Thank you and please let me know.
If it's actually coming from the where the bolt penetrates the pan, then that is probably an aluminum crush washer and you can wrench on it a bit. Others seem to be saying the cooling unit attaches to the pan with a gasket. If the gasket is leaking, then it is probably deformed and needs to be replaced.
I suspect it's a crush washer.
ctrlz is offline   Reply With Quote
Old 11-04-2021, 02:12 PM   #11
Wrecks24
Wrecks24's Avatar
Drives: Camaro LT1
Part it out
2021 Red Hot LT1
Wrecks24 is offline   Reply With Quote
Old 11-04-2021, 02:56 PM   #12
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
That is a plate and frame liquid to liquid, oil cooler. The layers are the plates that give a huge amount of surface area for heat transfer.
Looks like there is an O-ring seal (maybe two), between the heat exchanger and the oil plan. Should be very easy to replace and a cheap part. https://www.gmpartsonline.net/oem-pa...Y4LWdhcw%3D%3D
Should be as simple of disconnecting the oil and coolant lines from the exchanger, unbolting it, and replacing the seal.
Spaceme1117 is offline   Reply With Quote
Old 11-04-2021, 04:35 PM   #13
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
Also a good time to change the oil since a lot is going to leak out when you pull that cooler to replace the gasket.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 11-04-2021, 04:44 PM   #14
ctrlz
Also be ready for coolant top-off if you have to disconnect coolant lines.
Are the only bolts holding this the two which are visible?
camaro ss, camaro ss oil leak, oil leak
