01-24-2023, 06:03 PM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Jan 2023
2019 Camaro SS - Check Engine Light - 4 Injectors Misfiring
I have a 2019 Camaro SS with 20K miles on it. Live in Michigan.
Tried starting car last weekend and my check engine light comes on. (No issues before) These were the codes: P16E5 (Sensor Communication Circuit 3 High Voltage.) P0201 (Cylinder 1 injector misfire) P0203 (Cylinder 3 injector misfire) P0205 (Cylinder 5 injector misfire) P0207 (Cylinder 7 injector misfire) What was fix? Answer: Took it to a Chevy dealer and they said I have chewed up wires. Possibly from a rodent? Tech said it would take minimum 2.5 hrs labor estimate. He has to remove intake I believe to get access to the wires. They are ordering all new parts instead of patching wires. I gave them the go ahead.. Wanted to share in case some one else has the same issue or has experienced it before. Thanks. Last edited by Casey9105; 01-24-2023 at 06:49 PM. |
01-25-2023, 12:06 PM | #2 |
Drives: '16 2SS M6 Join Date: Aug 2019
When I read all the injectors on one bank, I was going to say mice chewed the wires.
Years ago had a customer's S10 Blazer towed into the shop for a no start. Opened the hood and a squirrel jumped out. That thing ate EVERY wire under the hood, including the fender mounted antennae. It cost $2000 in labor to fix it as the harness wasn't available new anymore.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
01-25-2023, 06:42 PM | #3 |
Drives: 22 ZL1 Join Date: May 2022
Just one bite II will solve all your problems. Has solved mine for years.
2022 ZL1 M6
01-25-2023, 07:24 PM | #4 |
Drives: 2002 Z28 Join Date: Feb 2022
I worked for a Ford dealer many moons ago....we had a Windstar minivan come in with a no-start. Mice had made a home in the pocket underneath the cowl where the main engine harness went into the PCM.....and chewed their way through it. I forget what that repair cost but the owner's insurance paid for it.....not cheap.
01-26-2023, 10:25 AM | #5 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Keep your hood open and windows rolled up , when car is stored and a light on, the little critters don't like light, my garage is like another room of the house , my place to relax , when not in use the door to house is closed and a light is always on. The garage door is open long enough to get a car in or out. A fellow years back I knew did this to all the cars in his shop , he never had issues.
2023 ZL1 A10 Shadow Gray Metallic
Tags |
2019 camaro, camaro ss, check engine light, p16e5 |
